Whose truck pulling with there dent?
Old Aug 5, 2013 | 11:15 AM
cabloom300's Avatar
cabloom300
Im looking for advice on what gear to pull in. I have tried 2nd low twice and i just seem to run out of gear with no tire spin. So should i use 3rd low, or 2nd high? The truck is a 76 highboy np435 400 horse 390. Thanks
Old Aug 5, 2013 | 06:27 PM
MeanGreen460's Avatar
MeanGreen460
What gear ratio and size tire are you running?
Old Aug 5, 2013 | 06:52 PM
MikePacey's Avatar
MikePacey
When I pulled my dent I did 4 low in 3rd gear, but I had a custom SM465 swap with different gearing. Gear ratio and tire size and type play a huge factor.
Old Aug 5, 2013 | 08:34 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I have a C6 but I run 4 low 1st and run about 5000-5500 rpm and that is about a happy speed. I would think that since your transfer case is a 2:1 Low, 2nd high might be higher than 3 low, not sure though. Try 3 low I think and see where you have more speed, 3 low or 2 high. I would go just one gear at a time.
Old Aug 5, 2013 | 10:16 PM
cabloom300's Avatar
cabloom300
According to a MPH calculator on the internet 2nd high and 3rd low seem to be almost the exact same. Im running 4.10 rear gear with 35 inch tires.
Old Aug 6, 2013 | 10:20 AM
Schickel's Avatar
Schickel
I pull mine ive git a 450 horse 400m manual trans. I run 4 low 2nd gear and it seems to do well with good wheel speed although I have 33 inch tires with a 3.54 gear ratio.
Old Aug 6, 2013 | 12:52 PM
cabloom300's Avatar
cabloom300
Do you know what tranny you have? NP435, T18, T19?
Old Aug 6, 2013 | 03:04 PM
Schickel's Avatar
Schickel
It is a np435 transmission
Norsegod127
1983 - 2012 Ranger & B-Series
Apr 4, 2015 10:49 AM
doubledip
Oct 7, 2014 01:59 PM
Granny Gear
27
Nov 23, 2010 10:21 PM
428HIGHBOY
Jul 15, 2007 06:11 PM
ken1mod
Aerostar
Nov 3, 2005 06:18 PM
