Manual low is solidly engaged in both directions, that is, manual low will slow down the vehicle. When first gear is engaged by the valve body in drive, it drives through a one way (sprag?) clutch so your coffee isn't knocked out of your hands when coming to a stop. automatic low drives through a free-wheel.
very good reason not to jerk down into 1st gear at speed unless absolutely necessary, manual shift into 1st only from stop. Sprags are fragile and expensive and usually cause other damage when they grenade.
