f150 78 351m timing help distributor swapped
I recently purchased a new distributor with the coil built in from kjb. I am having an issue with getting the timing marks to line up. When the engine is running I cant turn the distributor enough to get the marks any where near the pointer. The marks are on the opposite side of the harmonic balancer. When I put the light on the number 4 cylinder the marks line up like they are supposed to on the pointer. I am assuming I installed the distributor wroing somehow but the truck runs fine I would just like to fine toon the timing. Any help would be appriciated.
lawsonej
05-31-2016 07:40 AM
64'F100BobbySurfer
07-27-2015 06:56 AM
black58
11-21-2009 06:36 AM
