bell crank ball ?
Old Aug 4, 2013 | 06:29 PM
tn terry t's Avatar
tn terry t
bell crank ball ?
I have two 1980 ford f150's one has the 300, the other has the 302. the 300 is the four speed 302 is a auto we are puting the 4 speed in where the auto was yes I found a 302 flywheel. drive shafts where the same only problem I have run into is the "ball" that screws in the side of the engine block for the clutch swing arm are different the one I have from the 300 has threads larger than a half in the 302 is threaded for a half inch thread where would a feller start looking for this sized ball ?
Old Aug 4, 2013 | 08:18 PM
Franklin2's Avatar
Franklin2
It's not really a ball is it? Is it a shaft with a ball-looking plastic bushing clipped onto it?
Is this any help? http://www.lmctruck.com/icatalog/fd/full.aspx?Page=117
Old Aug 4, 2013 | 09:11 PM
tn terry t's Avatar
tn terry t
yes sir that number twelve is what I need I think the 300 just had the shaft with no bracket and it screwed into the block I was thinking the 302 did the same thing
THANK YOU VERY MUCH
rmalottwtes30
Sep 17, 2011 09:30 PM
waterlover34
15
Nov 15, 2008 08:24 PM
Scifi266
May 21, 2007 12:26 PM
fordbeast_80
Feb 24, 2006 09:08 PM
herothc2003
Oct 12, 2003 10:15 AM
