Trans Swap 3speed
Old Feb 24, 2006 | 07:00 PM
fordbeast_80's Avatar
fordbeast_80
Trans Swap 3speed
I have an '84 F150 with a three on the tree 300 six, ( I beleive it is a Ford 303 trans) will this trans bolt up to a 302 with out any probolems or modifications?
Old Feb 24, 2006 | 07:17 PM
Hooker Bob's Avatar
Hooker Bob
Yes they both use the same bellhousing. The changes will depend on where your bellcrank ball is mounted if is mounted to the bell housing no changes wil be needed.
If it's mounted to the block you will need the proper crank and ball for the V8. You will also need the proper flywheel for the 302.
Pat
Old Feb 24, 2006 | 07:21 PM
fordbeast_80
The 3 speed has a hydrolic clutch any problems there? the 302 is hooked to an SROD right now with a mech clutch?
Old Feb 24, 2006 | 09:08 PM
havi's Avatar
havi
I'll have the Roast Duck
just need to reinforce the firewall sheetmetal where you mount the hyd. res. as a precaution. 302 w/3 speed & 3.25 gears in my 74(2wd) made for a fun ride.
ford7872
May 14, 2016 09:50 AM
Mill2580
May 15, 2015 07:35 AM
Sayonara
All Things Towing
Jul 5, 2006 06:51 PM
RTM
Jan 19, 2004 10:17 PM
stevieray
Jun 24, 2002 01:11 PM
