I have moto metal wheels 951 chrome, bilstein 5100 shock with 2" level and firestone air bags on the rear. What tire size should I put on my F150 2wd?
275 60 20 (33)
305 55 20 (33.2)
285 60 20 (33.5)
275 65020 (34.1)
The 305/55/20 is a popular choice but is typically a heavy tire.
What look are you going for? Tall or wide or both? The 275/65/20 will probably look pretty good on your 2wd. The 285/60/20 is only a available from Goodyear from what I can tell. There is a 285/55/20 that you can get from BFG.
305/55/20 would probably look really good on your truck. There are a ton of tire makers that put out this size. Nitto. Toyo. BFG. Cooper. Yoko. Hankook. Just to name a few.
If you like the Terras then you might want to consider the Toyo Open Country AT2. It's a very aggressive all terrain in the 305/55/20 size. It's labeled "Extreme" by Toyo. It'll be my next tire.
