eab flathead question
Old Aug 3, 2013 | 07:39 PM
ford1954250's Avatar
ford1954250
i just yesterday picked up a EAB flathead all complete not locked up can turn it over with a battery and spins great got to give it a tune up so it will run . . but my question is i was old it came out of a truck so was there a certain year for the EAB ??? and was it for a car or truck ????
Old Oct 9, 2013 | 01:05 PM
52 4x4's Avatar
52 4x4
It's been a couple of months since your post, so you probably already got an answer to your question somewhere. I just found this part of the forum today. After 60 years, your engine could have a lot of swapped parts on it. If you are going by the markings on the heads, I would say you've got a '52 - '53 engine that's probably from a car. They were usually painted red when new. A '52 truck engine was still an 8RT, but not sure about the markings on the '53 truck heads. I've got EAC heads on my '52 pickup and they're from a '52 Mercury.
Old Oct 13, 2013 | 07:32 PM
55 f350's Avatar
55 f350
53 truck was still 8rt markings , my 52 customline was running an eab when new , but was replaced later in life by a 53 8rt . eab heads can handle .395 - 400 lift on the valves without machining , and have a small chamber of 69 or 71 cc for a boost in compression , so they are worth keeping . my 53 effie is running and 8ba short block that is soon to be freshened i hope , with the eab heads milled .010 for cleanup , and should be running like 7.8 compression .
anthony myrick
Feb 11, 2016 11:10 AM
ssg1957
Jan 17, 2015 08:43 AM
havi
21
Jul 3, 2010 03:36 AM
propane32
Jun 20, 2006 09:19 AM
marcveinotte
1947 and Older Ford Trucks
Dec 6, 2003 01:59 PM
