flat head v-8 heads
Old Jun 18, 2006 | 05:05 PM
propane32's Avatar
propane32
flat head v-8 heads
i just bought 2 51 f1 one of them has 8ba on the heads the other has eab on the heads what if any is the difference ?thanks,clyde
Old Jun 18, 2006 | 06:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
EAB's are the highest average compression (stock), 8BA's are close behind. The difference on a stock engine is minute. More important is that they don't have cracks
Old Jun 19, 2006 | 05:59 PM
propane32's Avatar
propane32
flat heads
thanks ALBUQ F-1 i thought there had to be some difference but i couldnt find any info on them now i have to get them unstuck. thanks for the info clyde
Old Jun 20, 2006 | 07:52 AM
SteV8e's Avatar
SteV8e
The original flathead engine for the 51 trucks should be an 8RT. The easiest identifier is the large clean-out panel on the bottom of the oil pan. Marking on the heads is not real reliable; my 8RT has no 3 character mark on the heads. I've seen another 8RT with heads marked 8BA.
Old Jun 20, 2006 | 08:07 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The chances of finding any flathead with the original heads is pretty slim after 50+ yrs, shops used to have stacks of heads ready (cleaned and machined) and would just throw on whatever was on top of the pile. My truck's engine is actually from a '51 car, and neither head is an RT head. Has the car pan, narrow pulleys, 3-blade fan, 8RT intake manifold. Mix 'n' match....
Old Jun 20, 2006 | 09:19 AM
mtflat's Avatar
mtflat
The blocks are all the same between cars and trucks, cam might be different in some cases.
Otherwise the only differences were bolt-on accessories: large oil pan cleanout, waterpumps, wide pulleys and larger diam pulley on the generator due to the higher rpms trucks tend to run (shorter gears), RT low comp heads and some other misc stuff that I can't remember right now.
Point being you can take an 8BA car engine, swap all the truck accessories over to it and ta da, you have an 8RT truck engine.
