E4OD Trans problems
Old Aug 3, 2013 | 10:32 AM
Jcgizmo69's Avatar
Jcgizmo69
E4OD Trans problems
Hey guys, new guy here, how you all doing? I have a 92 F150 ext cab with a E4OD transmission that dies on me when I put it in reverse. In drive, I have no problems, but as soon as I put it in R, the idle goes down below 1000 and dies. I was told to check the modulator or something to that effect but it turns out my version does not have it! Could someone please help me? Thanks in advance!
Old Aug 3, 2013 | 10:57 AM
White 97 xlt's Avatar
White 97 xlt
The E4OD is completely computer controlled, so the first order of business it to see if there are any trouble codes stored.... As most codes can make the E4OD go into limp mode, then all kinds of strange things start to happen..
To retrieve the codes you need to check here for how to do it for free: Fuel Injection Technical Library » How To Run a Self-Test
If counting light flashes isn't your thing you can get an Equus 3145 code reader at your local parts store or here: Amazon.com: equus 3145
Oh, and Welcome to FTE....
Old Aug 3, 2013 | 11:43 AM
Jcgizmo69's Avatar
Jcgizmo69
Thanks for the welcome and help! I went ahead and did the codes and I get that the EGR valve position sensor - signal voltage higher than expected (closed valve position). No other codes come out, would this be the issue?
Old Aug 4, 2013 | 01:08 AM
Jcgizmo69's Avatar
Jcgizmo69
Replaced the EGR Valve and now get more codes, but all pertaining to the EGR Valve, wow! Anyways, working on both issues and any help would be appreciated!
Old Aug 4, 2013 | 10:30 AM
Encho's Avatar
Encho
The Southernmost Mod
Your trans. is low on ATF, this causes the filter to fall inside the pan, which is a known cause of the symptom you describe. Measure the level while the truck is at operating temp while idling in Park. You can also check the E4OD mods link in mi sig, it should be an interesting reading.
Oh, and welcome to FTE bud!.
Old Sep 26, 2013 | 04:10 PM
Cowboydesperado's Avatar
Cowboydesperado
Did you figure out the problem? I'm having the same issue of stalling in reverse.
Old Sep 26, 2013 | 07:12 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
be sure to first check the fluid level.the e40d's are thirsty in R.
Old Sep 26, 2013 | 09:22 PM
Encho's Avatar
Encho
Like I already stated Cowboy, these trans tend to stall when the ATF level is low.
Old Sep 26, 2013 | 11:03 PM
blkF250HD's Avatar
blkF250HD
There is also an updated filter if I remember correctly, so that it cannot fall to the bottom of the pan and cause this problem. Some people have had luck just affixing a magnet or welding a nut to the pan below the filter to act as a spacer to keep it in place and off the bottom of the pan.
Old Sep 26, 2013 | 11:52 PM
Encho's Avatar
Encho
I made a retainer clip for mine, it's on my E4OD link down in my sig.
V8SHO
Oct 21, 2017 08:29 AM
aclaybor
Feb 3, 2017 01:32 PM
wag53
Jun 11, 2015 04:25 PM
kiohio1985
Aug 30, 2006 08:20 AM
doc_nomad
Apr 14, 2004 07:05 AM
