Thank you for the reply. Any idea how long or how difficult the job is to get to these sensors?
That would depend on your skills and your tool collection. Without knowing that I'd say3-5 hours.
BTW, before you pull the intake, you might want to access the connectors for the 2 sensors and swap them just to see if the code moves to the other side. The sensor could be good and you could be having a wiring issue. If it's a wiring issue then you would've pulled the intake for no reason.
