'47 starting circuit problems...
Old Aug 2, 2013 | 08:18 PM
47duallyFL's Avatar
47duallyFL
Ok, so Dad and I set the engine up to start today. No spark from the coil though. Tomorrow we'll look at the wiring better. Diagram shows a breaker of sorts in the line to the coil. We are having problems figuring out the position of the toggle switch. Is starting, right toggle or left toggle. The writing is gone. And does the position of the key have any bearing or is it just for steering locking. It is difficult to turn the key but we can pull the key out in full clockwise position. Feels very mushy though and we lack in confidence in it...
I left FL without a multimeter, of all things, and we may have to pick one up at Harbor Fr tools tomorrow....
Any help on the toggle position and/or some insight to the starting circuit would be greatly appreciated. We're almost there!!!!
Bill in North Babylon
Old Aug 2, 2013 | 08:49 PM
47duallyFL's Avatar
47duallyFL
So I used the forum search and came up with that the toggle is on position when left and off posiion when turned right. Good.
Now the key part. It seems to have 3 positions.
is full counterclockwise=off?
mid seat = on, or run??
full clockwise off and lock steering???
all my gauges seem waterdamaged so there's not much indication of power going anywhere. Guess I'd better buy a multimeter tomorrow....
goodnight
Old Aug 3, 2013 | 05:39 PM
newold46's Avatar
newold46
The key is only a steering column lock. The toggle switch has contacts that engage when you slide it to "on". Might want to start there.
Old Aug 6, 2013 | 05:58 AM
47duallyFL's Avatar
47duallyFL
thanks, newold46. I found a pic of the switch(on this site), took the switch apart and cleaned the contacts. That made a huge difference in output to the headlamps, running and turn lamps. But still nothing from the coil. Then I jumped from the battery straight to the coil. Nothing.
Since it was day 5 by then, I was runnng out of time and enthusiasm. When the truck gets delivered here(some nebulous time frame), I'll start with the points and condenser. Not one much for just changing parts out, ***** nilly, til I'm done with the troubleshooting. Though, lordy lordy, lots of parts need changing, cleaning and updating..
Thanks for the tidbit. It was helpful!!
Old Aug 6, 2013 | 06:07 AM
christurney77's Avatar
christurney77
It seems like the parts changing never ends!!!
cybercrone
33
Jun 26, 2015 07:43 PM
radar457
Apr 4, 2013 12:22 PM
Spitfire44
18
Feb 19, 2013 09:50 PM
verne56
Mar 24, 2006 07:00 PM
scalhoun
Feb 10, 2001 09:40 PM
