ignition switch problem?
Old Apr 1, 2013 | 01:48 PM
radar457's Avatar
radar457
I have a 79 with 400 and when I go to start it , I turn the key to start and it cranks fine, however it wont fire and run untill I ease up on the key till its almost back to the run position. It has gotten worse over the last year till its getting really hard to find that sweet spot on the switch that will let it fire and run. Now its about flooded befor I can hit just that right spot. I have put in 3 different key switches and 2 coils. Anybody run into this and know the fix or at least where else to look.
Old Apr 1, 2013 | 02:02 PM
redroad's Avatar
redroad
check for corrosion at cap and rotor
Old Apr 1, 2013 | 05:47 PM
crownver's Avatar
crownver
Check for spark while cranking. If no spark while cranking try hooking a wire from the battery to the coil and try that. If it starts then you're not getting power to the coil during crank.
Old Apr 1, 2013 | 06:16 PM
fmc400's Avatar
fmc400
MSEE
Remove the RED with BLUE stripe wire from the 'S' post of the solenoid so that you can hold the key in START without turning the starter. Measure the voltage at the positive terminal of the coil while you hold the key in START, and report your results.
ctubutis's Avatar
ctubutis
The DuraSpark II module has two power sources - one in START (I believe the white wire) and one in RUN (I believe the red wire). The module retards the ignition timing a few degrees in START, making a hot engine easier to start.
Might get out your multimeter and check for power at those wires (under the hood, at the module) in the respective key positions.
Typical wiring diagram:
Old Apr 4, 2013 | 12:13 PM
radar457's Avatar
radar457
I tested voltage today. I had 6.6 volts to the hot side of the coil with key in run position and 6.5 to 6.6 with key in crank position. I then ran a jumper from the battery to the hot side of the coil and checked to make sure I had 12 volts there, and it did the same thing ,it tries to start just before the key releases from crank to run position.
Put on a used ign module that I had in the shop and made no difference.....
Old Apr 4, 2013 | 12:22 PM
fmc400's Avatar
fmc400
MSEE
The next thing to do is to check power at the module as suggested above.
cb88
Electrical Systems/Wiring
51
Oct 4, 2019 08:31 PM
Echotop
Mar 20, 2017 09:04 AM
karljay
Dec 17, 2015 03:48 PM
Raist11
Jun 17, 2014 02:30 PM
Redneckryder
Sep 22, 2009 08:29 PM
