Ford 9" ?
Old Aug 2, 2013 | 02:33 AM
SuperDuty93's Avatar
SuperDuty93
Ford 9" ?
One of my trucks has a 9" rear in it. The gear ratio on the tag says 3.10. I want to swap in lower gears. Something like 3.89. I've read that I only need a ring and pinion cuz there is no carrier or something? Its a one size fits all sorta deal?
Thanks
Old Aug 2, 2013 | 08:42 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, with the Ford 9" you can swap in a 3.89 ring and pinion in place of the 3.10's.
While you're there, you might as well rebuild it with new bearings and seals.
One note, get more than one crush sleeve. Real easy to go too far when tightening the pinion nut. Once you've gone too far, you can't back up, you've gotta throw away the sleeve and start with a new one. Ask me how I know .
Old Aug 2, 2013 | 10:44 AM
SuperDuty93
Thanks Mike! Any sugestions on where to get a rebuild kit? Idk if one is better or cheaper then another.
Old Aug 2, 2013 | 10:54 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's one from Bronco Graveyard. Ford 9" Master Overhaul Kit,TIMKEN BEARINGS!
Before you order, make sure whether you have 28 or 31 spline axles and which type of axle bearing, roller or ball bearing.
If the tag is still on the diff, that can be decoded and give you all the info you need.
monstrs
Jul 30, 2018 07:26 PM
48' fordster
Jan 12, 2012 08:55 PM
StevensPoint
41
Sep 7, 2007 10:35 PM
59'er F100
Mar 25, 2007 09:47 PM
isomb3
Feb 25, 2002 11:32 AM
