ARP not oe torque Specs
Old Aug 1, 2013 | 10:25 AM
F-250 restorer's Avatar
F-250 restorer
I have an engine that failed. It was built by a 'pro.' We used arp rod bolts. Now I read that ARP uses its own torque specs on their site, and its own lube.
Does anyone have extensive experience using ARP bolts? If so, I'm wondering if you can explain them a bit, the procedure, etc. I read that they should be torqued several times when new before going to final torque?
Old Aug 1, 2013 | 10:31 AM
Poison Oil Racing's Avatar
Poison Oil Racing
ARP bolts are the best thing out there. Yes, they have their own torque specs and assembly lube.
the best thing I can tell you is to go to their website and read all about how they make the bolts and what their recommendations are for using them.
FWIW, I have never torqued them more than once.
Old Aug 2, 2013 | 01:11 AM
F-250 restorer
I know they are a great product, but buyers should be aware that they are torques differently than the oe bolts/studs. k
Old Aug 2, 2013 | 01:43 PM
keiths78f150's Avatar
keiths78f150
The ARP head studs for my 460 said 140ft/lbs which is also what was said in the Chilton as an OE spec.
Andyjman
Modular V8 (4.6L, 5.4L)
Apr 29, 2018 10:12 AM
jle70
Nov 14, 2009 02:06 PM
boltaction
May 20, 2009 08:02 PM
S_Bruce
May 23, 2007 11:57 AM
79_250RangerLariat
Dec 17, 2005 11:01 AM
