NEED HELP
Aug 1, 2013 | 02:13 AM
NEED HELP
My front upper shock mount on my 1973 f100 4x4 has a rubber insert that is mount on the spring tower. I do not know what the bushing is called, and there for can not order a new. one side has one, one does not. Again this is not on the shock or goes on the shock. It is around the top bolt, on top of the spring tower.
I can upload a picture if that would help
Aug 1, 2013 | 05:57 AM
They are a part of the shock, or should I say, come with a new pair of shocks.
Aug 1, 2013 | 10:00 AM
If its the shock bushing you are refering too, those top shock bushings are available from summit racing and most auto stores.
Aug 1, 2013 | 10:02 PM
i thought i made it clear it was not that. I'll upload a picture. it is not on a 1978....
Aug 1, 2013 | 10:08 PM
Are you referring to the bump stop? That's the only other rubber piece I see, I'll post an illustration in a few minutes.
Aug 1, 2013 | 10:10 PM
Quote:
Originally Posted by
mikeo0o0o0
no im not an retard people. I'll post a picture. It is exactly were i talked about. It probably stopped being on the trucks in 1977.
Aug 1, 2013 | 10:12 PM
Here's the illustration from the Ford parts catalog. Is the part you need basic part number 3020?
Aug 1, 2013 | 10:14 PM
mikeonetray13
?????? I didn't say anything about you being retarded! I'm only trying to help!
Aug 1, 2013 | 11:43 PM
mikeonetray13
got ya
Aug 2, 2013 | 04:01 AM
Bump stop maybe?
Reason: It's late, I'm retarded
Aug 2, 2013 | 06:53 AM
mikeonetray13
Clearly.
Only a genius would use "an" where the rest of the grammatically challenged world would use "a".
And for the record. Timing is retarded. People are not.
Aug 2, 2013 | 09:22 PM
i just looked at both sides. one the guy glued in the other is just bolted togther.... im either just going to weld it or force the bolt
Aug 2, 2013 | 09:41 PM
mikeonetray13
LOOK AT THE ILLUSTRATION I POSTED! (Post #7) What part do you need?
Aug 3, 2013 | 04:49 AM
mikeonetray13
Do both. In that order too.
Aug 3, 2013 | 08:04 AM
Just a heads up, if you want help around here try being a little more specific and polite. There are people on here that pretty much know everything about these old fords so just be patient and I'm sure someone will help you out.
