NEED HELP
Old Aug 1, 2013 | 02:13 AM
mikeonetray13's Avatar
mikeonetray13
NEED HELP
My front upper shock mount on my 1973 f100 4x4 has a rubber insert that is mount on the spring tower. I do not know what the bushing is called, and there for can not order a new. one side has one, one does not. Again this is not on the shock or goes on the shock. It is around the top bolt, on top of the spring tower.
I can upload a picture if that would help
Old Aug 1, 2013 | 05:57 AM
keiths78f150's Avatar
keiths78f150
They are a part of the shock, or should I say, come with a new pair of shocks.
Old Aug 1, 2013 | 10:00 AM
co425's Avatar
co425
If its the shock bushing you are refering too, those top shock bushings are available from summit racing and most auto stores.
Old Aug 1, 2013 | 10:02 PM
mikeonetray13
i thought i made it clear it was not that. I'll upload a picture. it is not on a 1978....
Old Aug 1, 2013 | 10:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Are you referring to the bump stop? That's the only other rubber piece I see, I'll post an illustration in a few minutes.
Old Aug 1, 2013 | 10:10 PM
mikeonetray13
no im not an retard people. I'll post a picture. It is exactly were i talked about. It probably stopped being on the trucks in 1977.
Old Aug 1, 2013 | 10:12 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's the illustration from the Ford parts catalog. Is the part you need basic part number 3020?
File Type: pdf
Old Aug 1, 2013 | 10:14 PM
mikeo0o0o0's Avatar
mikeo0o0o0
?????? I didn't say anything about you being retarded! I'm only trying to help!
Old Aug 1, 2013 | 11:43 PM
keiths78f150
got ya
Old Aug 2, 2013 | 04:01 AM
myoldfords's Avatar
myoldfords
Bump stop maybe?
Last edited by myoldfords; Aug 2, 2013 at 04:03 AM. Reason: It's late, I'm retarded
Old Aug 2, 2013 | 06:53 AM
LI250's Avatar
LI250
Clearly.
Only a genius would use "an" where the rest of the grammatically challenged world would use "a".
And for the record. Timing is retarded. People are not.
Old Aug 2, 2013 | 09:22 PM
mikeonetray13
i just looked at both sides. one the guy glued in the other is just bolted togther.... im either just going to weld it or force the bolt
Old Aug 2, 2013 | 09:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
LOOK AT THE ILLUSTRATION I POSTED! (Post #7) What part do you need?
Old Aug 3, 2013 | 04:49 AM
LI250's Avatar
LI250
Do both. In that order too.
Old Aug 3, 2013 | 08:04 AM
J ballan's Avatar
J ballan
Just a heads up, if you want help around here try being a little more specific and polite. There are people on here that pretty much know everything about these old fords so just be patient and I'm sure someone will help you out.
