1978 - 1996 Big Bronco
89 bronco ac problems
Old Jul 31, 2013 | 09:59 PM
Rhinoman89's Avatar
Rhinoman89
Just got this bronco and need a starting point for an ac fix. I'm a beginner to all this so please be kind.
Old Aug 1, 2013 | 01:27 PM
Southern Bronco's Avatar
Southern Bronco
Best thing to do if you have never worked on A/C's would be find a good shop or mechanic to check it out. Especially if has not been converted to R134a.
Old Aug 1, 2013 | 01:43 PM
Rhinoman89's Avatar
Rhinoman89
The problem with that is I've already put a grand in this thing and really want to save some money. How would I know if its been converted?
Old Sep 1, 2013 | 02:41 AM
dads1966's Avatar
dads1966
Check to see if the compressor clutch is engaging when you. Activate ac control. You should here it engage/disengage. You. Can verify if it has been converted to. 134a. By checking the charge connections 134a charge hose would not. Fit
Old Sep 2, 2013 | 10:36 AM
MadMatt65's Avatar
MadMatt65
A/C problems can range from a blown fuse (cheap) to compressors, evaporators and condensers. (EXPENSIVE!) You can see if the compressor comes on. If it doesn't....see if it has any refrigerant in the system. Depress the schrader valve at the dryer or near the compressor...GENTLY! If there is no refrigerant, or is low enough to not allow the compressor to come on, (You need gauges to tell if it's low) you have a leak. I would STOP there!! There is a high pressure AND low pressure cut out switch. (That protects the compressor) At that point, you are going to need some specialty tools...which can be VERY expensive!! Don't go down to the parts store and get the charge up kit! You'll just be wasting money. That will not fix the problem! Take it to a REPUTABLE A/C shop!! Lots of A/C shops have a "check out" special. Let them tell you what the problem is and how much it's going to cost. If you have never done A/C work......take it to a shop and save yourself a lot of time and aggravation....and $$$!!!
Robert Grant
Aug 29, 2017 08:04 AM
Robert Grant
1966 - 1977 Early Broncos
Aug 23, 2017 08:37 PM
obtunaman
Jun 9, 2006 06:46 AM
Chris_ce
1983 - 2012 Ranger & B-Series
Jul 6, 2003 08:44 AM
