Im looking for condenser installation diagrams for fords from 1973-1978. Im installing a/c in my 1978 ford bronco but need more pics of the condenser diagram. If anyone has any info plz send it my way.
Not sure what you're looking for....the condenser "condenses" High pressure gas (from the compressor) to a high pressure liquid. It then goes to a metering device (expansion block or orifice tube) then to a dryer and then allows low pressure liquid into the evaporator and turns to a low pressure gas and gets "sucked" back to the compressor.
Are you installing air into a Bronco "born without"?? There are after market kits out there that you can piece together if you have only certain parts. Try Vintage Air or Classic Auto Air. I've bought both companies from old projects. Being in SW Florida A/C is a MUST!!
