MAP sensor questionable
When the barometer drops it misses and clatters like the injectors are in very sad shape and the PERDEL readings bounce around on most cylinders while it passes the cylinder contribution test and injector buzz test every time. This problem is not related to rain or a water leak into the electrical system somewhere, just a lowered barometric pressure condition outside.
I checked the MAP through AE and it read 14.17 psi while the engine was cold and not running. I would pinch the MAP sensor tubing and watch the reading take a very brief and slight dip lower. I pulled the connector from the MAP sensor to clean it out and it went to a reference value of 13.56 psi if I remember correctly. Once re-connecting the MAP sensor I get a different value of 13.92 psi (28.34 inHg). Now when I try to squeeze the MAP sensor tubing there's no fluctuation in psi readout. I theorize that I have either fouled up the wiring or just strengthened a poor connection since I see a different reading now.
Of course I'm dying to re-start my engine tonight at 12:30pm to see if my problem is cleared up, but my truck is sitting tin the driveway right next to my neighbors house where their master bedroom is no more than 25 feet away.
In the meantime I wanted to see what you all thought. My research in the current local weather conditions translate to 14.9 psi based on taking the current barometric pressure of 30.06 inHg X .4911 giving 14.76 psi.
So my MAP sensor is reading off by 1 psi or 1.72 inHg. Whether this is a problem or not will likely be revealed tomorrow morning when I start the truck up.
I'll keep you all posted on what I find...
-Drake
Shouldn't I be able to see some readout when monitoring (Manifold Absolute Pressure - Hz) on AE? I ask because it reads 0.0 with engine running. Is that right?
Drake
I went out and bought a new MAP sensor from Ford for $161.00 (that's including tax. Installed it and before re-starting the engine again to see the results, I unplugged both negative battery cables for at least 2 minutes then re-connected them. Started it up and it was rough at first then began to smooth out after driving around for a while and laying my foot into the skinny pedal a few times. The engine runs a whole lot better now.
I spoke with a guy here in KC who services nothing but powerstrokes and I explained to him all the symptoms my truck had and he even drove around with me for a bit. He felt a really good candidate was my MAP sensor and he said it sounded like my truck's timing was off which would be caused by it going bad. He said that most of the time there are no codes for the MAP sensor when it's not functioning properly.
Using his scanner he looked at the difference between the MAP sensor psi and the Exhaust Back Pressure sensor psi and there was a difference of a about 0.5 psi. He said that 0.5 psi is the upper limit of deviation between these two sensor readings according to Ford. The funny thing was that through AE, I was repeatedly reading only a 0.1 - 0.3 psi difference. He said it was probably a bad MAP sensor. He told me that I should disconnect the negative battery cables for at least 2 minutes to allow the PCM to identify the the new MAP sensor, relearn the sensor readings and not simply think of the new data as incorrect readings (or something along those lines) once the engine is started back up again with new sensor in place. He said it's not necessary to do this with every sensor I replace, just ones that are important in controlling the engine timing. I don't know which others would fall into this category (maybe CPS?).
I'll keep driving it over the next few days to make extra sure the gremlins don't come back and let you know if it's continued to improve or not. The only thing that could get better is the ever so slight hint of a miss, but it's becoming almost imperceptible the more I drive around. My PERDELS are back into check now at about 0 - 0.2 for all cylinders except cylinder 8 which is about 0.4 - 1.2. EGT's are down, power is up, engine racket is nearly gone, runs more smoothly, CCV smoke coming from the tube routed under my truck has a different smell to it (I know that's weird), excessive black smoke upon hard acceleration is going away and is now more grey and much less of it.
My fingers are crossed.
Drake
Thanks Justin.
Slowly I'm working towards getting this truck to run well. I am making strides in the right direction recently. Replacing the MAP sensor was a big improvement. There Is still a little miss that remains and it's most evident in Park with me revving the engine at 1300 to 1700 rpms. In this rpm range the truck has this annoying shake. It's not dramatic, just annoying. It clears up at about 1800 rpms and beyond.
I am skeptical the MAP sensor (with good readings at idle) is the sole issue. I can see a MAP reading good at KOEO, then going sideways at higher pressures... but before/after should have been the same at idle. I wonder about the "reboot"... it may have been helpful right there.
I've even recently changed the PCM too. That change gave the engine a pretty big boost in the get up and go area (I have no idea why this cold be possible but it is true), but still have the miss. And yes, the miss rears it's ugly head the most when the weather turns bad (lower baro. pressure) and that's why I tried a different PCM (where the baro. sensor is). I'm not sure why the PCM swap gave me an improvement in power, but at this point I'll believe anything is possible after what I've experienced.
So today I decided that I would mess around with the CPS (black one) to see if I have any contact marks on it made by a cam gear that has walked off. Looked OK to me. I cleaned off the wire connector and CPS with contact cleaner and put it back in. Afterwards, I drove around a while and it ran better, but there was still evidence that the timing was not right (at least what I've concluded is a timing issue).
So I decided to try the battery disconnect for 2 minutes trick. Holy Cow! It went through a few miles of hunting for the right parameters while I varied my throttle pedal and all of the sudden it was running spot-on. Of course this will probably be a temporary relief seeing that I've had improvements in the past after I replaced this or changed that. But honestly, this is the BEST the engine has ran since I've installed it in my truck. It runs how I've always wanted it too right now. I'll report to you all if it holds up.
Now the question- Why did this help what I believe to be a timing problem with my engine? I believe I've read a thread somewhere here on FTE where someone took out their CPS and re-installed it and their truck ran better.
Just when you thought this was the end of the story for today.... I do have a strange thing that happens still when I mash the throttle until I get the EGT's up to the 1200 range, let off the throttle until the EGT's drop a bit and mash the throttle again. Nothing, no power AT ALL. It's ability to accelerate is completely gone. All I get is loads of grey smoke billowing out of the tailpipe. After I let it cool down for a few seconds it recovers it's power again. Anybody know what could cause this?
Drake
Loads of grey smoke... sounds like unburnt fuel. Have you looked into the IDM? Flooring it and having ZERO power sounds like none of the sticks are firing and just dumping raw fuel into the cylinders = not Bueno.
