Trans Fluid Change?
Old Jul 26, 2005 | 08:10 AM
Garff's Avatar
Garff
Trans Fluid Change?
I have a 2000 Expy with 80k miles. I have never changed the trans fluid like it should have been. Is it to late, should I leave it alone or change it? I have heard if you wait to long then its worse to change it. Thanks for the advise.
One more question, I pull a small RV(pop-up) with it, would a trans cooler be a good thing to add? Thanks.
Old Jul 26, 2005 | 10:18 AM
l-m tech's Avatar
l-m tech
80 k isnt to late,if it is a 4r70w use mercon5 if it is a 4r100 use mercon3.and a bigger trans cooler always helps.
Old Jul 26, 2005 | 10:19 AM
MOOK929RR's Avatar
MOOK929RR
too late? thats like saying its too late to change your oil... go ahead and change it. How much towing do you do? a pop up trailer is not that heavy... I would consider something like this, pretty cheap... a larger pan that allows to hold up to 4 more quarts of trani fluid, helps with the cooling a little.
http://www.jegs.com/cgi-bin/ncommerc...96&prmenbr=361
Old Jul 27, 2005 | 12:51 AM
broncoholic's Avatar
broncoholic
Problems arise with changing fluid on hard worked and neglected vehicles. What happens is the trans fluid breaks down and the tranny components where out over time. Changing to new "stronger" fluid ends up making these worn components fail, which they were going to do soon anyway. Bottom line is, change the fluid. If the tranny fails, it was going to fail soon anyway. And if it doesn't, then now you have new fluid which will prolong the life of the tranny.
As for the cooler, an auxilary cooler is almost always a good thing to add.
Old Jul 27, 2005 | 11:01 AM
kwaskow's Avatar
kwaskow
80K is not that bad - change it now and you should be fine.
Old Jul 29, 2005 | 03:38 PM
LoadedRound's Avatar
LoadedRound
When are you supposed to change trans fluid?
I changed mine at 50K (2000 Expedition 4.6L 4x4). Mostly highway. No towing.
Thanks
LR
Old Aug 1, 2005 | 10:15 PM
golakers's Avatar
golakers
How do you install an auxillary cooler, and how much $$ and time will it take?
Old Aug 2, 2005 | 09:40 AM
Darth Baiter's Avatar
Darth Baiter
Thanks
LR
RTFM - I believe it says every 30K. That's what my 99 calls for.
Old Aug 2, 2005 | 10:01 AM
natsoundup's Avatar
natsoundup
I change at 30k. Make sure you change the fluid in the torque converter as well as the transmission. You will probably find a decent amount of black clutch material in the pan. Transmissions do wear out.
