I hate to ask this question.....
Old Dec 20, 2013 | 05:49 AM
  #31
Hotwheelbill's Avatar
Hotwheelbill
Well, after a lot more reading and a little more understanding of my 6.0, I know I need to replace my Oil Cooler while I'm in there. So, best place to buy an updated oil cooler?
And what gaskets do I need for EGR D and Oil Cooler replacement?
Old Dec 20, 2013 | 05:56 AM
  #32
Hotwheelbill
Originally Posted by BLADE35
Run the gauge figure out what you Have
#1=ECT vs EOT @ 65mph steady (Leval ground Preferred but not a Deal Breaker ) Untill the Numbers STabilize at this time the Spread between them should be NO MORE then 15*f
#2= Check ECT & EOT & TFT after 12 hour cold soak should be Same
#3=Check
ICP & ICPV & IPR% when Hot at KOEO--Idle--2500rpm
#4= Check BARO & MAP & EBP at KOEO maybe BOOST psi at WOT
Edit, I think I got it. Going for a little ride and pick up VC9 AND new coolant and water.
OK, I have the OBDII Blue Tooth now and Torque loaded. Now I need a little more explanation of all 4 steps above please.
Old Dec 20, 2013 | 06:07 PM
  #33
Hotwheelbill
All good news today!!
As for my Flush, it came out all clean after an Hour and Half of driving with the vc9. I flushed again and then filled with D water.
I also found that after driving the truck all day to and from, the Oil and Trans temps never got above 5 from the Coolant temps of 188 at the highest. Boost was 22.5 under WOT (LOL, I run 42 boost on the ol Dodge with stock head and bolts). I have not looked at anything else yet, well I did not record it. Looking good right now!
Old Dec 20, 2013 | 06:10 PM
  #34
lupuseven's Avatar
lupuseven
I also found that after driving the truck all day to and from, the Oil and Trans temps never got above 5 from the Coolant temps of 188 at the highest. Boost was 22.5 under WOT. I have not looked at anything else yet, well I did not record it. Looking good right now!
Awesome! Glad to hear it all worked out
jmtbiggin
Apr 3, 2014 11:04 PM
Dyllan78
Jan 15, 2011 12:35 PM
2004SUPERDUTY
Sep 17, 2010 07:44 PM
Nitrous
Jul 19, 2010 08:50 PM
02GrayPowerStroke
May 6, 2008 10:12 AM
