fuel fillers generally use either a hose-in-a-hose to allow it to vent while fueling, or a small hose next to the main one for the same purpose - i'm not such which way your 2010 would be, but either way i suspect the vent hose is clogged or disconnected. try to remove the fuel filler neck and see if you can find out what failed inside.
I was told by a Ford parts man this sometimes happens when It gets very hot outside. Something to do with an anti-rollover valve, a check valve in either the fill or vent line..I should correct itself.
I see you are from SE Wisconsin. I am in the same area. We had very hot,humid weather last week. Now that the temps have come down to normal. Does the problem still exist?
I dont think this 2010 series has a fuel filter....
To be honest this is happening for couple of years now, but it is getting worse.
I got no check engine light so its got to be something simple, I think...
