Help Dangit
Old May 4, 2005 | 11:16 PM
82andBlueF150's Avatar
82andBlueF150
Help Dangit
I just bought an 82 f150 4x4 lwb 351w. The front fuel tank has been removed d/t it being rusted out long b4 I got it. When i go to put fuel in the rear tank I have to go at about 1 gallon per minute or else it splashes out and shuts pump down. It comes back up the filler vent so fast I can't get anywhere with it. yes 20 minute for 15-17 gallon fillup. This is driving me nuts. What can I do? Where do I start.
Old May 4, 2005 | 11:51 PM
Jebadiah04's Avatar
Jebadiah04
maybe you could put a vent hose in your tank???
not sure of the exact problem, but thats what i would try. Or else get a new front tank, that would be my first action....
Old May 5, 2005 | 10:30 AM
onion's Avatar
onion
lots of times the inner vent hose will kink if some one has tried to take off the fill hose. i would take the tanks hose off and inspect boththe fill hose and the inner vent hose.
Old May 5, 2005 | 10:49 AM
brokebronco's Avatar
brokebronco
Onion has it right. If the filler hose vent tube is even slightly kinked/collapsed you will get the condition you described.
Chris
Old May 5, 2005 | 08:06 PM
85F_150driver's Avatar
85F_150driver
might wanna try pulling the pump nozzle out a little. If i stick the nozzle in my truck all the way to the spring it will take a little then pop the pump handle. so i pull it out a little and i can fill fast as the pump will go.
Old May 6, 2005 | 08:19 AM
82andBlueF150
I"ve tried all the nozzle positioning tricks. I reached under and felt my fill spout and it is steel and straight. Is there a separate vent tube?
Old May 6, 2005 | 10:02 AM
onion's Avatar
onion
Yes There Should Be A Vent Tube In The Fill Tube
Old May 6, 2005 | 10:21 AM
82andBlueF150
so there's no fixing what's there, it's a matter of replacing it
Old May 7, 2005 | 09:50 PM
85F_150driver
there should be a little plastic tube inside the filler neck its about 1/2 inch diameter and it is held into the metal part of the filler neck and inside the tank. if its pinched or missing then you will hav to replace it.
Ratherbeefishin
Apr 13, 2014 09:24 PM
86'F-150
84
Jan 22, 2013 10:33 PM
kc5wxc
Aug 23, 2012 08:16 AM
magnum77
1997 - 2003 F150
Dec 18, 2009 05:37 PM
Schmids4.9l
15
May 22, 2005 11:53 PM
