Problem refueling
Old Jul 28, 2013 | 08:24 PM
Ford E-150 +'s Avatar
Ford E-150 +
Problem refueling
I got problem refueling my 2010 E-150. Pump would shot off after just a gallon or two.
We air blown vent lines thinking it might a spider web or something but it didnt help.
Any ideas ?
Old Jul 28, 2013 | 11:54 PM
Vanaddiction's Avatar
Vanaddiction
Just a thought, check the hose between the fill cap and tank, may be collapsed.
Old Jul 29, 2013 | 02:15 AM
joshofalltrades's Avatar
joshofalltrades
fuel fillers generally use either a hose-in-a-hose to allow it to vent while fueling, or a small hose next to the main one for the same purpose - i'm not such which way your 2010 would be, but either way i suspect the vent hose is clogged or disconnected. try to remove the fuel filler neck and see if you can find out what failed inside.
Old Jul 29, 2013 | 07:59 AM
Rick1025's Avatar
Rick1025
I was told by a Ford parts man this sometimes happens when It gets very hot outside. Something to do with an anti-rollover valve, a check valve in either the fill or vent line..I should correct itself.
Old Jul 29, 2013 | 08:01 AM
Rick1025's Avatar
Rick1025
I see you are from SE Wisconsin. I am in the same area. We had very hot,humid weather last week. Now that the temps have come down to normal. Does the problem still exist?
Old Jul 29, 2013 | 08:48 AM
Ford E-150 +
I did checked and its seams to be fine
Old Jul 29, 2013 | 08:51 AM
Ford E-150 +
I dont think this 2010 series has a fuel filter....
Old Jul 29, 2013 | 08:53 AM
Ford E-150 +
To be honest this is happening for couple of years now, but it is getting worse.
I got no check engine light so its got to be something simple, I think...
Jtsarby
May 6, 2015 05:44 PM
biggymrat
May 20, 2011 03:24 PM
dakonthemountain
Sep 10, 2008 04:48 PM
82andBlueF150
May 7, 2005 09:50 PM
