Help decoding vin number!!!!
Old Jul 28, 2013 | 05:14 PM
th3 gunslin9er's Avatar
th3 gunslin9er
Hi everyone! I'm new to the forum. I'm wanting to restore an old Ford truck that my uncle gave me. This is my first restoration so I'm hope you'll can help me decode the warranty number and plate and give any helpful advice for a beginner, it would be greatly appreciated. I believe it's a 1963 or 64 F110 or f100 4WD but as for the rest I don't know. Warranty number. - F11CR462991.
W.B. - 120.
Color. - M.
Model - F110.
Body - B81.
Trams - F.
Axle - B5.
Max G.V.W. LBS - 5600.
Cert. Net - 135.
H.P. R.P.M. - 3800.
D.S.O - 71
Old Jul 29, 2013 | 03:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
This is my first restoration so I'm hope you'll can help me decode the VIN and Warranty Plate and give any helpful advice for a beginner, it would be greatly appreciated.
VIN: F11CR462991 / W.B. 120 / Color: M / Model: F110 / Body: B81 / Trans: F / Axle: B5 / Max GVWR lbs: 5600 / Cert. Net HP: 135 / RPM: 3800 / DSO: 71
Welcome to FTE
F11 = F100 4WD
C = 292 2V
R = San Jose CA Assembly Plant.
462991 = 1964, assembled October 1963.
120" Wheelbase.
M = Wimbledon White.
F110 = F100 4WD, 5,600 lbs. GVWR
B81: B = Medium Blue Crush Vinyl & Medium Blue Check Stripe Woven Plastic / 81 = 81B Custom Cab.
F = Borg Warner T-98 4 Speed Manual Transmission.
B5 = Spicer/Dana 60.2 Rear Axle / 4.10-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,600 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 29, 2013 | 06:29 AM
fabmandelux's Avatar
fabmandelux
Welcome to FTE!
Moved to proper forum.
Old Jul 29, 2013 | 03:31 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
Old Jul 30, 2013 | 08:02 PM
th3 gunslin9er
Thank you very much all of you, and thank you for moving me to the correct forum. I tried to post pics on this form for you but my iPad will not copy and past the link for some reason. I added several pics on my album and will add more as soon as I can. I will keep updates as well. Thank you again for all of you'lls help!
Old Aug 13, 2013 | 02:23 PM
NumberDummy
Originally Posted by jasch
I am new to the Ford Truck Enthusiasts forum. I just purchased a 1962 Ford F100 Unibody. I am very excited about purchasing my first classic vehicle. I am like others here on the site. I would like to know more about my warranty plate information.
VIN: F10JD301346 // WB - 114 / Color - T / Model - F10J / Trans - A / Axle - 11 / Max. G.V.W. lbs - 05000 / Cert Net HP - 114 / R.P.M. - 3600 / D.S.O. - 61
Welcome to FTE
F10 = F100 2WD
J = 223 1V I-6.
D = Dallas TX Assembly Plant.
301346 = 1962, assembled June 1962.
114" Wheelbase.
T = Sandshell Beige.
F10J = F100 2WD, 5,000 lbs. GVWR
A = Ford 3 Speed Manual Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
61 = Dallas TX Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Aug 14, 2013 | 05:55 PM
jasch's Avatar
jasch
Thank You so much!
Thank you so much for the valuable information. Everyone has been very helpful. I am so happy that I am a part of the Ford Truck Enthusiasts Forum.
jasch
Welcome to FTE
F10 = F100 2WD
J = 223 1V I-6.
114" Wheelbase.
Old Aug 14, 2013 | 06:15 PM
arctic y block
I sure wish ya could get yer pics in the thread here. It's a pain to go search for them. I can't save them when they are big to copy them here. But you can. This is what I see and the best I can do. And it took me 22 minutes to get this here
Nice truck to start with. And this is the right and best place to get all the help that's out there.
Good luck mate.
fereo0
May 29, 2014 11:24 AM
Squirrel987
16
May 14, 2014 03:29 PM
Alaskan66
Apr 7, 2014 01:33 PM
Foggerman
Large Truck
Mar 10, 2014 08:54 PM
TheCableGuy
Sep 19, 2013 08:18 PM
