Numberdummy guidance needed...
Old May 9, 2014 | 02:09 PM
Squirrel987's Avatar
Squirrel987
I am the third owner of this fine vehicle. It had a dump truck box in it!!! As soon as I can figure it out, I will add pictures. The truck is almost all original. I do need to find a tailgate. Thank you for your help in decoding this for me.
Warranty Number: F25DL631513
WB: 129
Color: 8
Model: F252
Body: 381
Trans: N
Axle: 24
MAX GVW LBS: 7500
CERT NET HP: 172
RPM: 4000
DSO: 42
Old May 9, 2014 | 03:27 PM
svolpone's Avatar
svolpone
hit the "Go Advanced" button and add the pictures as an attachment.
Old May 9, 2014 | 07:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
^ OP is not a Supporter member, so cannot add pics this way. ^
Warranty Number: F25DL631513 / WB: 129 / Color: 8 / Model: F252 / Body: 381 / Trans: N / Axle: 24 / MAX GVW LBS: 7500 / CERT NET HP: 172 / RPM: 4000 / DSO: 42
Welcome to FTE
F25 = F250 2WD
D = 352 2V
L = Michigan Truck Assembly Plant.
631513 = 1965, assembled December 1964.
129" Wheelbase.
8 = Not listed for 1965, it's most likely B = Caribbean Turquoise.*
F252 = F250 2WD, 7,500 lbs. GVWR
381: 3 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl / 81 = 81A Standard Cab.
N = New Process 435 4 Speed Manual Transmission.
24 = Dana 60 Rear Axle / 4.10-1 / No Limited Slip / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
42 = Fargo ND Ford District Sales Office, where the original selling dealer ordered the truck from.
* 8 ~ 1966 = Springtime Yellow.
Old May 10, 2014 | 03:07 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html Bob's link is not working. Can someone in the know tell me why?
How to upload pictures to the FTE Forums. - YouTube. Thanks Sam Rusty_Old_F250. Best we can find is that this video was done by Gundown64
Old May 14, 2014 | 01:30 PM
Squirrel987
Old May 14, 2014 | 01:37 PM
NumberDummy
Truck is painted Caribbean Turquoise, the hubcaps are from a 1967/68 F250.
Old May 14, 2014 | 01:44 PM
Squirrel987
My 1965 F-250 Camper Special with Dump Bed
Still trying to post a picture..
Old May 14, 2014 | 01:58 PM
NumberDummy
Linkee no workee.
Old May 14, 2014 | 02:08 PM
Squirrel987
Earlier post has links now...
Old May 14, 2014 | 02:26 PM
Squirrel987
Is the Dump Box from Ford or aftermarket?
Old May 14, 2014 | 02:44 PM
svolpone's Avatar
svolpone
ohhhh, i guess i'm special now! i say the poster should invest the small fee so they can do it, and to support the site if they plan to be here often.
Old May 14, 2014 | 02:47 PM
NumberDummy
It has the correct Styleside bed, but this bed was converted into a dump bed by an aftermarket source.
Old May 14, 2014 | 03:08 PM
Squirrel987
So, does the Dump Bed make this Ford more or less desirable?
Old May 14, 2014 | 03:10 PM
svolpone's Avatar
svolpone
Isn't that like asking if blonde hair makes a woman more or less desirable? It depends on what you like.
Old May 14, 2014 | 03:18 PM
arctic y block
Here it is.
