I have a 97 f 250 with a stock turbo on it the question is I have play when I push it srom exhaust to and to intake side I have no play up and down that I can see is there an issue
and i have a question too. i have a e99 , and my upgrade turbo wise would be the d66 also.
so does this mean that i have the same turbo as what was put in the 94.5 thru 97 trucks ?
if so, i guess i could look for one from those years to use as a back up rebuild then correct ? thanks , chris
The one for the 94.5-97 won't work on the E99. They have different mounting for the exhaust housing
