Missouri Chapter Join Chapter , Leader:77&79F250
Richs Ol red's thread
Old Dec 18, 2016 | 09:23 AM
  #181
whiskey runner's Avatar
whiskey runner
wow you are getting a lot done rich.... you are moving along faster than a herd of turtles...
Old Dec 18, 2016 | 10:36 AM
  #182
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes I know, but at least I am getting back at it.
Old Dec 18, 2016 | 11:34 AM
  #183
earthquake68's Avatar
earthquake68
It's about time you get it rolling again!
Old Dec 18, 2016 | 11:43 AM
  #184
whiskey runner
you dont have to be fast..just steady......i guess i better get moving too... would not want you to have your red truck done before i get my red truck done...
Old Mar 28, 2017 | 05:39 PM
  #185
77&79F250's Avatar
77&79F250
It's the little things that keep me going.
Removed and sold the tilt wheel over the weekend, now to work over or replace the steering shaft and install a none tilt.
Old Mar 28, 2017 | 11:57 PM
  #186
brian1080's Avatar
brian1080
Come on, it's a race to see who gets their truck on the road first. ��
Old Mar 29, 2017 | 06:11 AM
  #187
whiskey runner
it does not matter who is done first.. we will all get participant trophy's anyway...... dont want to risk hurting anyone's feelings....ha ha ha ha ha ha
Old Mar 29, 2017 | 07:10 AM
  #188
77&79F250's Avatar
77&79F250
I would bet on YOU, I am sure you will drive your nice yellow truck to my place and ol red will be setting right there as you seen it....the last 2 times.
For me its a matter of just not enough free time or lack of motivation to get on it nightly.
Old Mar 29, 2017 | 11:12 AM
  #189
brian1080's Avatar
brian1080
Mine has been mainly motivation for the past year. That's a killer, but I'm finally getting over it.
Old Apr 1, 2017 | 07:21 PM
  #190
77&79F250's Avatar
77&79F250
Worked over the fit of the push bar and its bolted on for good. Installed the diifferent steering column and installed the same instrument cluster.
Had to work over some bulbs, but I have dash lights now. I do not have a high beam indicator in the cluster (headlights do go from high to low with the dimmer switch).
And I HAD turning signals one time, now a no go. I hate elec issues.
Old Apr 1, 2017 | 07:35 PM
  #191
whiskey runner
i could drop by one day rich.. and watch you fool with the wires, maybe make a few suggestions or something...
Old Apr 1, 2017 | 08:27 PM
  #192
77&79F250's Avatar
77&79F250
I hate to mess with wiring...Next sat we are going to that race I talked about, we leaving around 3:00 PM.
But I sure could use a hand figuring it out, if you would not mind lending me an experienced hand earlier in the day?
Old Apr 1, 2017 | 09:13 PM
  #193
ubereal2's Avatar
ubereal2
Rich could there be a ground wire that isn't grounded, or a pin to a connector that is bent?
Unk Bob
Old Apr 1, 2017 | 10:32 PM
  #194
77&79F250's Avatar
77&79F250
I believe the t/s issues are being caused by my replacement steering column...probably the turning signal switch. It all worked before the swap in. Plug on both ends look good.
I believe I need to ground/hard connect/mount the dimmer switch to take care of that issue?
Old Apr 1, 2017 | 10:58 PM
  #195
whiskey runner
i will look around to see if i can find a experienced hand to bring with me....
the dimmer switch does not need to be grounded to work.. i will see if my busy schedule has any openings so i can sneak up that way
