Hi. On a road trip and discovered a stream of red fluid following me. I thought it was maybe boiling over or filled too full but tranny temp gauge hasn't moved.
Any ideas what it could be or how to diagnose more? Maybe something simple that doesn't require a huge transmission bill?
You're gonna have to take a look underneath to see where the fluid is coming from. It's not uncommon to have the front seal fail which can cause this, but there are other places that can leak as well.
yes it can be bad to have a leak for at least 2 reasons: 1. depending on severity of the leak, if system is run too low, damage to the pump among other internal trans parts will occur 2. can be fire hazzard
I pulled the dust cover from the flywheel area as it seems like the oil is coming from the hole on the bottom. However it's hard to know for sure as everything is wet. It seemed wet on the transmission side of the flywheel and dry on engine side...but not as wet as I would expect given the amount of oil leaking.
It leaked for sure Thursday but I didn't notice it again until tonight. Both nights there was a full on puddle underneath that stopped dripping eventually. But when starting and driving again an hour later, no noticeable leak.
Any thoughts on the wisdom of adding a "stop leak" product? Transmission oil seems to be "full". Can these be checked on level ground with the truck off or does it need to be checked running and in gear? Dipstick has a cold and hot level indicator.
Any thoughts on the wisdom of adding a "stop leak" product? Transmission oil seems to be "full". Can these be checked on level ground with the truck off or does it need to be checked running and in gear? Dipstick has a cold and hot level indicator. Don't check the trans when cold.
Thanks
Torie
If it's full you don't have a big seal problem since you say it isn't constant and stop leak for the trans softens the seals and not needed here. You will probably end up putting a new seal and front pump bushing in.
He really doesn't know if it's truly full or not.... he didn't even know how to properly check fluid to begin with. If he checked fluid level with vehicle OFF the level will read much higher than actually in there.
Not trying offend I was just making a valid point in response to post#9 above
Fair enough. First automatic. I "thought" there was something about checking it in drive obviously with a helper in the brake but now I know. Level when checked warm with truck idling in park is right at the end of the dipstick.
I'll buy a jug of ATF and check it every hour of my 4 hour trip home and then get it checked out properly. Thanks for all the help and ideas.
Well I made the 5 hour trip. I put 2.5L of ATF in to get it up to the correct level. I didn't seem to lose any today. Strange. I'll be able to investigate further now that I am home.
