electric fuel pump install
Old Jul 27, 2013 | 05:41 AM
hwy92truckn's Avatar
hwy92truckn
im installing a new airtex e8090 fuel pump, i replaced the old plastic line with new rubber line, what my question is will this pump pull the fuel out of the the tank to prime its self ? its going to be mounted close to the tank right were the selector valve wasyup its gone and front tank only and lower than the tank...
Old Jul 27, 2013 | 06:12 AM
Skip1970's Avatar
Skip1970
subscribing! would like to know too!
Old Jul 27, 2013 | 07:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
i would not use rubber line on the suction side of the pump. you are setting yourself up for a collapsed fuel line.
Old Jul 27, 2013 | 08:31 AM
hwy92truckn
thanx tjc, ill make sum changes there...
Old Jul 27, 2013 | 08:39 AM
hairyboxnoogle's Avatar
hairyboxnoogle
If it is a roller-vane pump, or most any pump actually.. it should pull fuel just fine within a given distance. If you get the good rubber line its actually just fine for suction, never had a problem with the cheaper line either.
Old Jul 27, 2013 | 10:10 PM
Kleenax's Avatar
Kleenax
Electric Fuel pump install
Here's how I did mine. Thought you guys would like to see the thread that I posted. Has some pics and references of how I did it and what I used.
I have to say, the pump works PERFECTLY, and so does my installation!
https://www.ford-trucks.com/forums/1...mp-wiring.html
Old Jul 28, 2013 | 04:13 AM
hwy92truckn
kleenax, that looks great, got mine workin, and truck is runnin great, thanx for the help guys...
Whosyour51
2004 - 2008 F150
Jun 27, 2019 08:25 PM
ford4x4956
Sep 15, 2009 09:28 PM
ohiofordnut
May 23, 2009 03:12 PM
stockernavstar
May 18, 2006 12:55 PM
dbarracuda
Oct 24, 2002 11:31 AM
