Florida Chapter Join Chapter, Leader: Ronnie Shierling
fuel problem
Old Jul 26, 2013 | 11:35 PM
carlos813's Avatar
carlos813
fuel problem
I have a 97 Ford Expedition that will start and shut off but if and if I step on the gas and will stay on but as soon as I get off the gas and shuts off
Old Jul 27, 2013 | 08:50 AM
carlos813's Avatar
carlos813
Can anybody help
Old Aug 1, 2013 | 05:38 AM
dixie460's Avatar
dixie460
Classic symptom of a failed IAC (Idle Air Control) Valve. Tap on it with a screwdriver handle and see if it'll unstick. Should run normal then, but it ain't a permanent fix.
To fix it right, you'll have to take the valve off and clean it, or replace it with a new one.
Old Aug 1, 2013 | 08:09 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by carlos813
Can anybody help
You would get A LOT more help if you posted this in the Expedition forum.
Old Aug 2, 2013 | 01:08 AM
carlos813's Avatar
carlos813
A mechanic look at it he says it a clog line so he going to drop tank and line and injector the sprayed carb cleaner and it stays on
Old Aug 5, 2013 | 06:10 AM
dixie460's Avatar
dixie460
Uh, alright, if you trust that mechanic then have at it, but I'd think if you had a fueling problem your engine would NOT stay running by giving it gas manually. I've seen this happen before, if you are being 100% accurate with your symptoms then I'll say I'm 100% certain it's your IAC valve. I could be wrong, but if it were my truck I'd be at the parts store already buying an IAC valve (after confirming it as I mentioned above).
jawsok
Oct 7, 2013 08:01 PM
gregnorwood
Jun 14, 2007 01:34 PM
laurags
Nov 23, 2006 07:30 PM
laurags
Nov 9, 2006 05:18 PM
eddie57
Nov 17, 2004 08:41 AM
