2002 Expedition Starting Problems
Old Jun 14, 2007 | 09:35 AM
gregnorwood's Avatar
gregnorwood
My 2002 Expedition will not start. Acting like fuel problem. Starts and dies. starts and dies. Service Engine light has been on am in the process of checking codes there. No new fuel bought recently so have no reason to suspect filter but will change that to rule it out. Any help.
Old Jun 14, 2007 | 09:42 AM
dkoenig's Avatar
dkoenig
Idle?
If it refuses to Idle, check the IAC, Idle Air Control Valve. Easy to clean (mixed results) or replace.
Don
Old Jun 14, 2007 | 09:49 AM
kailor's Avatar
kailor
If it will barely start, and you have to frantically pump the gas pedal just to keep it choking and spitting and sputtering before it dies (and definitely dies when you come off of the gas pedal), then I second IAC valve.
Another possibility (at least on my 2000 Expedition), if I have 1/4 tank of gas or less, and am facing downhill, it won't start. Get the Expedition facing uphill, and it will start all day long!
Old Jun 14, 2007 | 12:22 PM
gregnorwood
Thanks Kailor that was exactly the problem. I had less than 1/4 tank, added about a gallon, it started and hasn't quit since. Thanks.
Old Jun 14, 2007 | 01:34 PM
kailor's Avatar
kailor
Glad to help gregnorwood! Welcome to the forum. This particular forum is absolutely wonderful. When we all pass on our tidbits of information, it can save someone else lots of time and cash.
jawsok
Oct 7, 2013 08:01 PM
Chazrik
20
Dec 12, 2011 12:11 PM
DOC1KOC1
Jan 4, 2010 12:16 PM
Expoli
Jul 15, 2009 09:31 AM
k_mowery
Jun 23, 2007 01:44 AM
