Is my engine overheating?
Old Aug 14, 2013 | 08:10 PM
clinkfield's Avatar
clinkfield
Is my engine overheating - test
This first message is just a test. I want to see the difference between "Post Reply" (which is what I am doing now) and "Quick Reply" (which is what I usally do).
Old Aug 14, 2013 | 08:46 PM
The Masked Rider's Avatar
The Masked Rider
Redneck, tell me that's photo shop. Could a fan blade really stick through the hood?
clinkfield's Avatar
clinkfield
The original question was "Is my engine overheating?" I've concluded that it is not.
I bought a new temperature sensor/sender since they are only $10. The gauge now goes more to hot side than with the old sensor. It pegs to right. See pic below.
On advice from this forum, I bought an infrared thermometer. (Fun to play with!) I realize that none of this will show the actual INTERNAL water temperature. The temperature on top of the block next to the temp sensor reads 170's. The temp at the thermostat housing read the same. The hose from the engine reads 160's. The top of the radiator reads 170's.
The water is flowing across the top of the radiator - implying that the water pump and thermostat both work. See movie below.
The pic below showing the thermostat was taken right after removing the hose with the engine hot. It looks to me like it is open.
So why would the gauge say "BURNING HOT!!"? There is a pic showing the wire going to sensor. Is that the right one?
Movie: 20130814_204940.mp4 Video by clinkfield | Photobucket
Old Aug 14, 2013 | 09:06 PM
gangstakr's Avatar
gangstakr
Ok as I'm reading this, it is said you have a 1964 with a 292 is this correct?
If it is a 64 with a 292 I'm wondering about your instrument cluster. Did you install that one?
Hey N.D. When was the sweep cluster introduced? Wasn't it early 65? I've never seen one in a 64 unless installed by someone other than factory.
If this is the case, is the (*resistance) the same in the two different gauges?
*see below for meaning.
* =I have no idea what resistance means but it sounded good)
Old Aug 14, 2013 | 09:17 PM
1972RedNeck's Avatar
1972RedNeck
Yes they can. No that's not a photo shop. Somebody over on a Chevy forum had it happen.
clinkfield's Avatar
clinkfield
gangsta - no, it's a 66 with some kind of v8. Vin number F10YRB62140.
Old Aug 14, 2013 | 10:57 PM
gangstakr's Avatar
gangstakr
From reading this thread, post #6 and on refers to a 292 in a 64 f100
I think from the very beginning, you should have posted what you have or think you have, and the VIN #
Your profile says you own a 64 f100
When you don't provide necessary information many people jump to your profile and ***-u-me, that what's in your profile is what your talking about.
A few threads made reference to a 292
At that point you should have cleared up my confusion.
Now your VIN say's 352 engine so, I guess were dealing with a 352 and not a 292
Old Aug 14, 2013 | 11:07 PM
SuperSabre's Avatar
SuperSabre
You left a number out of your VIN so we can't tell when your truck was made, but your engine is (or was when it left the factory) a 352 cubic inch FE V8, 2bbl, and your truck was built in San Jose, CA. Is your fuel guage playing up as well? If so, your gauge problem may be with the Instrument Voltage Regulator. I'm confused by your picture showing the red/white temp sensor wire possibly going to the coil? The red/white wire should go from the temp sensor, through the firewall junction to the temp gauge. Is that where yours is going? Good luck with your quest.
Old Aug 14, 2013 | 11:30 PM
The Masked Rider
Hey Robert, 'resistance' is what wives do.
Old Aug 14, 2013 | 11:32 PM
The Masked Rider
Redneck, that picture is priceless... Lucky he wasn't working on the motor when it cut loooooose.
Old Aug 15, 2013 | 03:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
"Who goofed? I've got to know!" -Howard Cosell on MNF
Originally Posted by SuperSabre
You left out a number of your VIN
Last 6 digits of the VIN is the serial number. 1967/77: Serial number begins with a letter...followed by 5 numbers.
gangsta - no, it's a 66 with some kind of V8. VIN: F10YRB62140.
You sure it's a B and not an 8 (that makes sense for a '66)?
F10 = F100 2WD
Y = 352 2V
R = San Jose CA Assembly Plant
B62140 = 1967 .. assembled July 1966.
862140 = 1966 .. assembled May 1966.
1966 serial number range: 732,000 - 913,999 / 1967 serial number range: A00,001 - B99,999.
Robert: C5TZ-10838-A .. Sweep Speedo Instrument Cluster Bezel = 1965/66 F100/250 2WD Custom Cab/Ranger.
Old Aug 15, 2013 | 12:57 PM
C G B's Avatar
C G B
Originally Posted by 1972RedNeck
Did I hear "flex fan"?
That is awesome
Old Aug 15, 2013 | 04:05 PM
  #28
clinkfield's Avatar
clinkfield
NumberDummy - I'm sure you are correct. The "B" is probably an "8". So I have a 352.
SuperSabre - There are three wires coming out of the bundle where the tape is unraveling. Before the split, the bundle of wires comes from the firewall.
Others - thanks for all of the laughs!
But ... does anyone know how to diagnose the temperature gauge?
Old Aug 15, 2013 | 07:20 PM
  #29
gangstakr's Avatar
gangstakr
Go to the 67-72 forum, look at the thread titled "Overheating Blues" page two. CougarJohn has outlined the way to get your gauge to read what is correct. Then do some research on it and you'll have a good idea how to get the gauge dialed in.
Old Aug 16, 2013 | 03:54 AM
  #30
NumberDummy
With an 8 in lieu of the B, you have a 1966 .. not a 1967. The Y VIN engine code...decodes to 352 2V for 1966 & 1967.
74f100sc
May 4, 2019 08:16 AM
quakerj
Dec 24, 2014 12:43 PM
restoringmy46
27
Jun 26, 2008 11:23 PM
rodeostar546
Nov 25, 2005 07:01 PM
pacers40
1983 - 2012 Ranger & B-Series
22
Dec 19, 2003 10:59 AM
