How accurate is your fuel gauge?
Had an interesting moment this morning, I was crusing along in my truck and it said 1/8 of a tank (trying to squeeze it, bad idea I know) and as I was driving I could tell it wasn't running right, but I thought I was imagining it. Well a little while later it started loosing power, I canned it and all I saw was the tach getting lower and lower till finally it died and I'm along side the road. (A busy 4 lane highway I might add)
Crank crank crank. Nothing, no smoke, no nothing.
So I thought "Oh great! I should have bought a CKP sensor!" Of cousre I also felt that I had to wait for somthing to happen to do it. Also a bad idea.
So I let it sit thinking it might fire back up in a bit.
Cranked and cranked nothing.
So I switched to the full tank (I know what a concept! I need to stop being so cheap!) And I cranked again. No smoke or anything. So for the heck of it I kept cranking, and I started to see smoke, and the engine speed started to increase untill finally it was running. Horrible idle but running.
I let it sit and run for a bit, then took off and it cleared itself right up. And It ran great and I got everything else done. So pretty sure this was just being stupid and letting it run out of fuel. I would have thought though that I would have had to the red before I ran out. I guess not!
Needless to say I did stop at the International dealer and bought myself a CKP sensor anyways.
So my question is, is this common on our trucks? The fuel gauge thing. Believe me this will be the last time I let it fall below 1/4 before switching tanks!
I have never run a diesel out of fuel before but now I will know the warning signs of when to switch if it ever happens again.
Would it be worth it to pull the tank down and replace the pick up lines? I guess what Im asking is there alot involved in doing it?
On my truck when the needle hits empty I have a 10 gal reserve in the rear and 4 gal reserve in the front.
I always try to run the rear tank empty before I switch. You now know when to switch. When you start loosing power you have plenty of time to switch. I always try to do it on the highway.
When I get a chance I want to pull the rear 38 gal tank and see if I can adjust the float to be more accurate.
Richard
Richard
on mine i had just got it, it started sputtering and losing power. i thought it was something major as i had 1/8 left on the guage. no other vehicles i've owned had issues before the E. (wife seems to think that stands for Enough). I pulled into a parking lot and started looking for leaks, loose wires, smoke, something. nope switched tanks and it came back to life. i had heard horror stories of guys running diesels dry and having to be towed to a shop to prime the fuel system!! Ahhhhh not ok. now i switch at 1/4 and fill up at the next 1/4. I get about 2 weeks out of that.
glad you didn't end up actually stranded, and now you know when to quit being cheap.
Haha yeah I learned my lesson. I haven't had a vehicle that did that either. I do have one that when it's right on E you better get to the gas station! I think I'll just do that and not go below 1/4. That's a safe bet.
And yes I'm glad I didn't get stranded with air in the system! Although can our trucks get air locked being direct injection? Just curious. It took it a while to get going but when I saw the smoke I knew it would eventually fire. And it's run fine every since.
