Sponsored by: Real Truck
Help with dually
Old Jul 24, 2013 | 08:47 PM
westay34's Avatar
westay34
Help with dually
Hey guys I figured someone on this site could help me. Its been a year ago that I found a sleeve that goes over the stud on the rear wheel of a dually when putting rims on. It helps keep the two rims aligned. You slide this sleeve on two suds and the put all the lug nuts on with the exception of those 2. Tighten everything down then remove the sleeves and place the last two studs and the rims are aligned on the studs the same. You use this when you don't have centermatic hubs. I found it on a website but I cant seem to find it again. Does anyone know what I am talking about?
Old Jul 24, 2013 | 09:27 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
I'm not sure what year DRW you have but my 2000 and 2013 both used the hub to alien the rims, I have to apply grease on the hub so the wheel won't stick to the hub because it's that close.
Denny
Old Jul 25, 2013 | 07:29 AM
scraprat's Avatar
scraprat
Top Answer: 5
Same with the 2008, use some anti seize between hub and rim, rim to rim or it's a real PITA to get them off. Make sure to off set the valve stem so you can get at them when mounted.
Old Jul 25, 2013 | 04:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
I think what the OP is trying to say is that he is using lug-centric rims on his DRW instead of hub-centric rims, like the stock wheels.
HVFDFIREFIGHTER1618
Feb 10, 2019 08:18 PM
br42164
May 23, 2013 07:22 AM
lakewood
Sep 25, 2011 06:39 PM
karljay
General Automotive Discussion
Jan 6, 2010 01:45 AM
bigjer_
Apr 6, 2003 11:28 PM
