Bench Check 6-V Generator
Old Jul 24, 2013 | 06:36 PM
Steves55's Avatar
Steves55
I recently bought a spare generator for my 223 I-6 and would like to bench test it. What is the best way to do this? Many thanks. Steve
Old Jul 30, 2013 | 07:51 PM
arctic y block's Avatar
arctic y block
I hook them to a battery and if they motor than they will also charge.
Old Jul 30, 2013 | 09:39 PM
5 Star's Avatar
5 Star
Artic Y Block
Your the first one I have heard use that method in over 40 years. Thats the very same thing I used to do and have done so all along.
Old Jul 31, 2013 | 03:46 PM
arctic y block
It's prolly been 40 years since I have done it that way.
Old Aug 1, 2013 | 08:12 AM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Which posts and order do you use to connect to a battery to make it spin? Assuming a positive ground system.
Tom
Old Aug 1, 2013 | 09:13 AM
raytasch's Avatar
raytasch
Believe Nothing
Tom
Hook the negative to the armature post and positive to ground last. If I remember right, either way will work.
Old Aug 1, 2013 | 11:33 AM
old_dan's Avatar
old_dan
Motorizing a generator is also a good way to re-apply some magnetism to the iron core field magnets. When a generator sits around unhooked, the magnets can get too weak to start generating.
With an installed generator, you can flash the field, or better, unhook the belt and hook the battery (neg lead in this case) to the Armature connection...sometimes you have to give the generator a little spin to get it going.
Dan
Old Aug 2, 2013 | 05:32 AM
pineconeford
I found this helpful thread here dating back to 2008:
https://www.ford-trucks.com/forums/7...regulator.html
Tom
Old Aug 2, 2013 | 09:09 AM
GLR's Avatar
GLR
Going back a few years.. If I remember correctly....as Ray said. The generator will run as a motor at a "high speed" then if you ground the F (field) the generator speed will slow down.
Old Aug 2, 2013 | 02:15 PM
Steves55's Avatar
Steves55
Thanks for the feedback. A local shop offered a free bench test so I took and had it checked; it works! Now I have a good spare.
90pioneer
Apr 28, 2023 06:23 AM
George D.
Jul 26, 2010 02:06 AM
Mr. Finch
Mar 9, 2005 09:05 PM
Kake
Appearance & Dress-Up
Nov 5, 2002 10:51 PM
