03 6.0 problem
Old Jul 23, 2013 | 01:21 PM
danny2313's Avatar
danny2313
03 6.0 problem
I pulled my egr valve when i got home from work last night to clean it. While it was out i cranked the truck and let it run for maybe 5 seconds to see if it wiuld blow any crap out of the egr valve hole. I reinstalled the egr valve and went to crank the truck and whrn i truned the key to crank all the relays under the dash clicked like normal but it would not turn over. after a good look over to make sure i had not knocked something loose at the egr, i went to the starter and found the 2 long bolts around the starter moter loose. i finger tightened them and when i got out from under it to get a socket i reached in and hit the key and she fired right up. i killed it and tightened the bolts and went to bed calling it good. got up this morning at 4:30 to leave for work and same thing. it would not turn over. any ideas?
Old Jul 23, 2013 | 02:20 PM
big inch's Avatar
big inch
Have you checked the battery terminals? Do you have a voltmeter?
Old Jul 23, 2013 | 02:34 PM
danny2313's Avatar
danny2313
i have a voltmeter, but i was in a hurry this morning, i will check the voltage to the starter this evening.
Old Jul 24, 2013 | 06:47 AM
danny2313's Avatar
danny2313
got home , checked voltage and had voltage to starter when trying to crank. replaced starter and she cranks fine now. thanks for the help.
Old Jul 24, 2013 | 03:21 PM
big inch's Avatar
big inch
Good deal!
BillyBob69
21
Feb 16, 2016 08:25 AM
El Padrino
17
Mar 9, 2013 08:25 PM
MorrisCtyFord
Jan 20, 2013 01:15 PM
amiller609
Nov 22, 2011 10:51 PM
travisd
Sep 15, 2009 04:36 AM
