Ok, i posted this question several months ago, however the problem hadn't happened again..untill yesterday. After sitting idling for a minute or so when i put it into drive or reverse it immediatly shudders, or dies. At the same time the water in fuel light and check engine light comes on. This doesn't happen everytime just every once and a while... three times today. It is a '02 with 63,000 miles diablo delta 54/78 flip switch and a homegrown tymar intake. Thank you all for any ideas on whatever this might be?
Does your check engine and water in fuel light stay on after restarting? If so do you have a way to pull the codes? Could be the cam position sensor. When was the last time the fuel filter was changed?
Make sure the chip still fits snugly in the PCM, and that the blades are making good contact. Then go out and get a spare cam sensor. Pull the codes as well, you might have an ICP or IDM problem.
rvfiver.... no, after restarting everything is fine and it runs no prob.
Since my first post earlier i had some timme to experiment and found out that it must be something the chip is changing with the tranny. When i am in 54 or 78 and idle for a minute or so it stalls when put into gear. When i leave it in stock mode it can idle and then go into gear everytime no problem.
Cookie... since this only happens when the chip is engaged, that wouldn't be the CMP would it?
So my question:
Ken, if i sent the chip to you, could you reprogram the chip so that the 54 and 78 settings do not change any tranny settings? If we left the tranny in "stock mode" might this help the problem? Thanks yall for the help
