tranny cooler - need recommendation
Old Jun 12, 2003 | 02:41 PM
cuongnhu's Avatar
cuongnhu
Question tranny cooler - need recommendation
I have a 96 Explorer, 2WD, 4.0 l. I would like to add a tranny cooler to it. We sometimes tow a small camper through mountains. Any recommendations on the appropriate aftermarket product? (I assume the factory unit is out of sight)Anything special I should consider?
Thanks for all input.
Old Jun 12, 2003 | 05:05 PM
viiidude's Avatar
viiidude
The bigger the better. Check out this link:
BMM-70264
Price: $49.95
www.summitracing.com
B&M seems to be the best value. On the install, make sure you use barbed fittings. The slight flare should ensure the tranny oil hoses stay in place once clamped. You may need to go to http://www.bulkpart.com/
to get the fittings you need (I think they run about $17) and pickup some additional feet of hose if you do that.
Pretty much whatever you do will beat the cost of a stock cooler install.
Good luck
Old Jun 13, 2003 | 06:13 AM
SplashMan's Avatar
SplashMan
What he said... Summit has the best selection and great service. If you let them know what you need/want, they will steer you in the right direction. As for the stock cooler, only Explorers with the tow package came with them and they are located on the right side of the radiator in the front. Something else to think about may be a aux filter for the tranny. You can get a kit for that at Summit too.
jskadberg
Jun 9, 2015 10:20 PM
Pinky Demon
Oct 4, 2009 01:03 PM
firemanp
Feb 7, 2007 03:39 PM
fnx4wheeler
Jul 21, 2006 07:28 AM
bdh
Jul 1, 2002 01:39 PM
