Sponsored by: Real Truck
Amber Flashing Light Install
Old Jul 21, 2013 | 03:03 PM
sailorman3's Avatar
sailorman3
I'm installing a new amber light on my 2013 F250 signal cab and was wondering where most people run the wires into the cab. It has a magnetic mount and I didn't want to put a hole in the roof. I have a cap on the truck and I also don't have a sliding rear window. This will not be a temp. install. Has anyone ever put the wires in through a hole in the 3rd brake light? Any help would be great. Thanks in advance.
Old Jul 21, 2013 | 04:40 PM
Jameson JC's Avatar
Jameson JC
Mine were put through the highlamp brake light, the center light that is on top of the rear window glass.
I have since disconnected it.
JC
Old Jul 21, 2013 | 05:47 PM
tjc transport's Avatar
tjc transport
i ain't rite
i run the wire through a small hole drilled in the floor under the rear seat, put a grommet in the hole, then seal the hole with silicone.
run the wire up between the box and cab.
or for a full size arrow stick i run the 12 conductor wire through a hole in the firewall treated the same way with grommet and silicone, and run the wire along the frame, then up between the cab and box.
Old Jul 21, 2013 | 08:14 PM
Firefighter 1406's Avatar
Firefighter 1406
Me too. I also put weather pack connectors under the the cab. That way if down the road you need to remove it you don't have to remove the whole wire.
ZachManXLT
1997 - 2003 F150
Mar 12, 2015 01:28 PM
A/Ox4
Jun 25, 2011 06:11 AM
mblanken881
13
Feb 15, 2009 10:25 PM
X36
Oct 1, 2007 10:09 PM
RodneySheets
Electrical Systems/Wiring
Oct 9, 2004 09:20 PM
