No Start Diagnosis
Old Jul 20, 2013 | 02:08 PM
love2truck's Avatar
love2truck
No Start Diagnosis
I have a 2000 Ford F250 with the 7.3 Diesel engine. It has 297,000 miles. Beginning of last winter I started having to plug the truck in at night to insure it would start the next morning. Now I only plug it in when the temperature is cold. The other day I was driving it when it died on me and I couldn't get it to start again. The engine cranks over but still doesn't start. When I turn the key on you can hear the fuel pump, and the glow plugs seem to be as normal. There is diesel in it, so I know it didn't run out and is the problem. (Although recently someone ran the truck out of fuel 3 times) The code that I received when testing was P1293. My diesel mechanic suggested it was the camshaft sensor. But after reading more into it I think I might have a bad IDM module. Any thoughts or suggestions?
Old Jul 20, 2013 | 02:25 PM
Stewart_H's Avatar
Stewart_H
P1293 High Side Open Bank No. 1 (Right)
Usually indicative of a problem with the UVCH (Under Valve Cover Harness) or something associated with the harness, like a bad/burned plug, loose connection etc.
I hope he didn't suggest that after you told him the code.
Are you able to pull the passenger side valve cover and inspect the harness?
Stewart
Old Jul 21, 2013 | 08:44 AM
Tugly's Avatar
Tugly
If you have a multimeter and know how to test Ohms, you can test the resistance to the solenoids. Over the driver-side valve cover, there is a 42-pin connector with a 10mm nut holding it together. Don't have your key in the ignition when this is apart. D Driver side - even-numbered injectors, P Passenger side - odd-numbered injectors.
Old Jul 26, 2013 | 12:58 AM
Tinkerbell73's Avatar
Tinkerbell73
When my camshaft position sensor went out, it wasnt immediately. It would die at random times and take odd times to start.
Old Jul 26, 2013 | 03:34 PM
Tailgate77478's Avatar
Tailgate77478
And THIS IS WHY myself and most others here do all maintenance and repairs ourselves. I am NOT a mechanic, but with the help of places like FTE and the members here (sometimes in person), you can fix 90% of problems yourself...even ones that you would think are insurmountable (how you like THAT word, Roland?!?!? ).
Let us know how this turns out...
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
milehi_350
Dec 29, 2012 05:54 AM
Mrfist1987
Dec 10, 2011 06:44 PM
1985Ford Gal
General Automotive Discussion
Jan 16, 2009 06:32 PM
dbw70
Nov 23, 2006 06:00 PM
