I feel like I cannot win lately. Just Finished my EBPV delete buttoned everything up and went for a test drive everything worked amazing. Like a whole new animal! But now my a/c is no more. My clutch is not engaging. Fuse is good. tapped front of clutch with a/c on and no engagement. Compressor spins freely. Jumped low pressure line, nothing. If i manually jump clutch it engages fine, but the plug isnt putting out power. I'm coming to a loss right now can anyone give me some more troubleshooting steps?! The Haynes manual is about worthless and every thing on the net is about an intermittent clutch operation.
Thanks
02 7.3 4x4 excursion
Well I found mine finally. My high pressure switch took a crap. Jumped the pig tail and what do ya know my compressor kicked right on. I'm hoping I can just r&r it but I have a feeling ill have to Evac and refil. Anyone know?
Pop is right here (as usual).
Just disconnect the wires, screw the bad one off, screw new one on, reconnect wires and you are finished.
I got a similar problem with my A/C.. are you talking about that switch that is next to the compressor and at the top of the steel line pipe with wires attached?
