A/C quit...
Old Jul 20, 2013 | 04:37 PM
Stolher's Avatar
Stolher
Yup that's the one. If you look from the front of the engine it's right next to your dipstick for engine oil
Old Jul 20, 2013 | 04:44 PM
clintbonnie's Avatar
clintbonnie
Hey thx.. I am going to get a new..
Old Jul 20, 2013 | 04:51 PM
clintbonnie
Is it call a PRESSURE CYCLING SWITCH ?
Old Jul 20, 2013 | 04:52 PM
Stolher's Avatar
Stolher
I think it was $24. My local orielys had it in stock
Old Jul 20, 2013 | 04:53 PM
Stolher's Avatar
Stolher
Orielys part number 20916
Old Jul 26, 2013 | 08:45 PM
clintbonnie
Well... I replaced the pressure switch in the line next to the dip stick, clean the contacts and the problem of "off" and "on" air conditioning is still there.. Any other suggestions.. the clutch is working but drops off after a few minutes..The pressure is good, check by a mechanic..Seems to be worse when it gets above 85*.. when you really need it to work..
Old Jul 26, 2013 | 11:48 PM
SpringerPop's Avatar
SpringerPop
Clint,
Intermittent? Have you read this?
SpringerPop's Compressor Clutch Air Gap
It's worth a shot, and should cost you nothing.
Pop
Old Jul 27, 2013 | 11:14 AM
clintbonnie
Hey .. a big thx Pop. I will check it out today and let u know the results..
Old Jul 30, 2013 | 08:23 PM
clintbonnie
Well that was as easy cheap fix..!! I remove the clutch plate after measuring a .041 feeler gap as you instructed Pops. Remove the one and only small washer shim and replaced it with a thinner one and it now measures .020 gap on the clutch plates.. and it's FIXED the problem of off and on air conditioning.. It works Great !! thx again..!! I love this forum..!!
96_F250_Deezal
Sep 27, 2016 01:27 PM
bbacon
Aug 10, 2014 06:50 PM
Diesel_Brad
13
Jun 26, 2012 03:31 PM
2000Ford2000
13
Aug 17, 2007 09:58 PM
spivster
1997 - 2003 F150
May 23, 2007 02:53 AM
