Im getting RF HE2 10's (400RMS , 800 Peak , DVC) and was wondering what kind of amp to get , I was looking for a high watt 4 channel @ 2 ohms , but someone said to bridge the speakers. Can someone explain bridging to me? Also , Im getting a Pioneer-7500MP Receiver , and it has MOSFET 50x4 , will that be enough to run atleast tweaters? Becuase I have some other amp thats purple under the seat , have no idea what it puts out , I need to check if thats what runs the mids allready. The same person said id only need a 500x2 @ 2 amp if I were to bridge the speakers. DOes bridging make the sub only one channel or what? Thanks for any help.
You can use your HU to power the tweeters. Tweets don't need much juice to get goin'. You can wire those subs into a mono load. What is the VC config? Dual 4 ohm or dual 2 ohm? If dual 4 ohm, get an amp (Class D mono, not a 2 channel...too inefficient, and more expensive) that does at least 800 watts rms at 1 or 4 ohms. If it's a pair of dual 2 ohm subs, get an amp that does at least 800 watts rms at 2 ohms. The JBL 600.1 is a cheap amp (under $200) that will work in either situation.
What the differance between hooking up a 2 channel amp at 2 ohms to run 1 sub per channel and 1 channel bridged running 2 subs in parallel at 4 ohms
I bought the JBL 180x2 for $99 on eBay!
It's 180 x2 at 2 ohms and 360x1 at 4 ohms.
Which is the better way to go? Can someone explain how that works?
