ACCELERATION ISSUE
Old Jul 18, 2013 | 04:07 PM
Misn 1's Avatar
Misn 1
ACCELERATION ISSUE
Since Monday, when I press the accelerator pedal, there is a slight hesitation before the RPMs go up and the truck begins to accelerate. Idling is steady and smooth at 690 RPMs and the truck runs great. I do have the Blue Spring upgrade, only use OEM filters, and change them on schedule. I also add approx. 8oz of Cetane Boost at every fill-up. Any ideas what could be causing this?
Old Jul 18, 2013 | 04:27 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Can you post MAP-BARO-EBP at Key On Engine Off (KOEO), idle, and 2,500 rpm?
Could be:
Sticking turbo
Sticking EGR valve
Clogged map tube at intake
Bad MAP sensor
Clogged EBP sensor tube
Bad EBP sensor
Or something completely different.
Old Jul 18, 2013 | 05:36 PM
dc2842002's Avatar
dc2842002
Could be:
Sticking turbo
Sticking EGR valve
Bad MAP sensor
Bad EBP sensor
Just out of curiosity what are typical readings for MAP, BARO, and EBP at KOEO, idle, and 2500 rpm?
Old Jul 19, 2013 | 07:34 AM
Misn 1's Avatar
Misn 1
UPDATE - Left work yesterday evening and had to make a stop on the way home. Got back in the truck after being in the store for about 15 mins and she would spin but not start up. Popped the hood and took a look but nothing appeared wrong. Just for the sake of doing something, I removed the harness from the EGR Valve. Guess what? She fired right up! I clipped the harness back in and proceeded home. And guess what again.....no acceleration or hesitation issues at all. Unbelievable!!!
I pulled and cleaned the EGR Valve last summer while I was changing the oil cooler. And it was fairly clean. Guess I will do it again this weekend.
Now for another question: could this have been the problem or just a coincidence?
Old Jul 19, 2013 | 09:30 AM
Rusty Axlerod
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to
KOEO=Key On Engine Off =record value
Low Idel (truck idel on its own)=record value
High Idel (2500RPM)=record value
Values below are given in this order^^^Left to right
Acronym Key On Low Idle High Idle Operating Range Measurement Units Description they are listed in this order left to right helps to break it down like rows and collums.
MAP 96 (14) 96 (14) 103 (15) 41 - 324 (6 - 47) kPa (PSI) Manifold Absolute Pressure
MAP_V 1.30 1.33 1.40 0.5 - 4.5 VOLT Manifold Absolute Pressure
BARO 96.5 (14) 96.5 (14) 96.5 (14) 50 - 120 (7.3 - 17.4) kPa (PSI) Barometric Pressure
EP 103 (15) 110 (16) 110 (16) 55 - 607 (8 - 88) kPa (PSI) Exhaust Pressure
EP_V 0.8 1.2 1.3 0.4 - 4.7 VOLT Exhaust Pressure
Thanks Benny.
Yes, It could be the EGR.
Ebrenz
Feb 20, 2018 06:21 PM
Edogsf350
Jun 7, 2016 08:54 PM
Jleworth
Feb 17, 2013 01:49 PM
tgtrotter
Feb 8, 2013 06:31 PM
bismic
Apr 19, 2008 11:55 PM
