Egr issue?
Old Feb 18, 2018 | 10:42 AM
Ebrenz's Avatar
Ebrenz
Egr issue?
2006 f250 6.0 140,000 miles.
Truck had bad egr systoms, surging sputtering etc. cleaned valve, very dirty. Ran fine for a month. Got on it on hwy started doing it again. Runs great at idle as soon as I touch accelerator it surges hard and sputters. Changed egr valve still doing it. Starts no problem idles fine even at high idle. As soon as I touch accelerator it does it again. I’m stumped. Thinking something else is dirty???
Old Feb 18, 2018 | 12:08 PM
HT32BSX115's Avatar
HT32BSX115
Howdy,
Welcome aboard!
There might be a couple of things going on and while it might be good to connect a scan guage or similar to read some of the parameters, it will probably tell you everything if you can find someone with a Ford IDS (or equivalent scan system)
These engines are not easy to diagnose without connecting to some sort of scan tool.
Old Feb 18, 2018 | 12:13 PM
Ebrenz's Avatar
Ebrenz
Yup, working on that now, I’ll let you know what it says.
Old Feb 18, 2018 | 04:18 PM
Katie Isabel Hunt's Avatar
Katie Isabel Hunt
If you think its egr related, also try cleaning the ebp tube. I have read that you can clean the ebp sensor aswell but didnt dare personally, as mine was relatively clean. You cant shove anything up there in chance you break the membrane which means a new sensor replacement.
Old Feb 18, 2018 | 05:56 PM
Ebrenz's Avatar
Ebrenz
Thank you the egr was really plugged up.i did read that too, I’ll check it out and reply, thanks
Old Feb 19, 2018 | 12:26 AM
Katie Isabel Hunt
I would advise as others, go spend the $30 total for an elm 327 and torque pro. If your egr system needs cleaning like that(unless your doing 50,000km a month) theres an underlying issue that should be addressed. some readings on temps and pressures goes a long way into understanding wth might be going on there
Old Feb 20, 2018 | 02:41 PM
Ebrenz's Avatar
Ebrenz
It was the crankshaft position sensor. Thank you
Old Feb 20, 2018 | 03:01 PM
bismic's Avatar
bismic
It would be great if you would post how you narrowed it down to the CKP.
Old Feb 20, 2018 | 05:47 PM
Ebrenz's Avatar
Ebrenz
I finally got a hold of a good code reader. Read a PO336.
Old Feb 20, 2018 | 06:21 PM
bismic's Avatar
bismic
ty .
PSDx3
6.4L Power Stroke Diesel
21
May 27, 2015 01:56 PM
luketrot
Sep 18, 2010 05:47 PM
orcasmagical
1983 - 2012 Ranger & B-Series
15
Sep 9, 2006 12:24 AM
paulg
Dec 3, 2000 12:20 AM
KTMNealio
May 26, 2000 02:42 PM
