CODES P0401, P2284
Old Feb 2, 2013 | 02:43 PM
tgtrotter's Avatar
tgtrotter
CODES P0401, P2284
Hello, I'm trying here.
P0401 Came on this morning after having 0EVD/0EVM and was suggested return truck to stock and reset ECU by remove/replace #10 fuse under hood. Ran/drove/started truck few times and now pulling grade empty EVD 104 / EVM 100. Is this a turbo fart ? Sticky vanes, bad boot ? EGR valve just cleaned afaik working.
P2284. Truck will start and run fine KOEO 0 ICP 11 IPR, IDLE 580 ICP 20 IPR HI IDLE 1500rpm 820 ICP 15 IPR
but then when revved to 2000rpm all hell breaks loose. Truck will continue revving 1-2 seconds and idle 875 ICP 28.8 IPR.
Hate to throw parts but I was told replace ICP sensor.How many things could this be ?
Honestly I've only bought Fords for myself but I'm one step away from tossing in the towel. Just spent 2k getting egr/oil cooler replaced and now this crud pops up.
Tim
Old Feb 2, 2013 | 02:44 PM
BLADE35's Avatar
BLADE35
sorrey about your troubles
What year truck??????
How Long ago was work DONE??????
Old Feb 2, 2013 | 02:48 PM
BLADE35's Avatar
BLADE35
Tim
Hold the Throttle lets do some Diagnostic tests before you throw parts
Lets check the ICP Sensor to start with
Are you using a ScanGaugeII?????
Have you ever cleaned the EGR Valve???
Old Feb 2, 2013 | 02:53 PM
BLADE35's Avatar
BLADE35
P2284 ICP Injector Control Pressure Sensor Circuit Range/Performance A difference in commanded versus actual injection oil pressure was detected.
For this^^one post ICPVolts at KOEO
P0401 EGR Exhaust Gas Recirculation Flow Insufficient Detected EGR valve, EGR position sensor bias, EP sensor bias
For this Check these at KOEO
BARO
MAP
EBP
Old Feb 2, 2013 | 03:04 PM
tgtrotter's Avatar
tgtrotter
ok thanks benny gotta setup my sg for icpvolts. will post soon
Old Feb 2, 2013 | 03:08 PM
BLADE35's Avatar
BLADE35
here some the common ones you should have always
V-REF
TXD=07E0221155
RXF=046245110655
RXD=3010
MTH=006433330000
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D00500000
NAM: BAR
Exhaust Back Pressure
?TXD: 07E0221445
?RXF: 046285140645
?RXD: 3010
?MTH: 001D00500000
?NAM: EBP
KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI)
FICM Logic Power (Volts) (Should be 12 volts)
?TXD: 07E02209CF
?RXF: 0462450906CF
?RXD: 3010
?MTH: 006401000000
?NAM: FLP
KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5
FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced.
?TXD: 07E02209D0
?RXF: 0462450906D0
?RXD: 3010
?MTH: 006401000000
?NAM: FMP
KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford)
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
?TXD: 07E02209CE
?RXF: 0462450906CE
?RXD: 3010
?MTH: 006401000000
?NAM: FVP
KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5
Inj. Control Press. (ICP / HPOP)
?TXD: 07E0221446
?RXF: 046205140646
?RXD: 3010
?MTH: 003900640000
?NAM: ICP
KO=0 LI=625.5 HI=1400-1450 OR=0-4045
ICP Voltage (Volts)
?TXD: 07E02216AD
?RXF: 0462451606AD
?RXD: 3010
?MTH: 004827100000
?NAM: ICV
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
?TXD: 07E0221434
?RXF: 046285140634
?RXD: 3008
?MTH: 0DCA03E8000A
?NAM: IPR %
KO=14.84 LI=24 HI=40.60 OR=0-50 %
MAP and Volts should already be in the gauge.
MAP Voltage (Volts)
TXD: 07E0220900
RXF: 046205090600
RXD: 3010
MTH: 000104000000
NAM: MPV
Note: This one seems a bit odd, but try it out and let me know if you need finer resolution. This one will go by whole numbers, but the range is something like +/- 32 Volts which seems weird for a sensor – they’re usually 0-5 volts
EP Volts (Volts)
TXD: 07E02216AE
RXF: 0462451606AE
RXD: 3010
MTH: 000100800000
NAM: EPV
Note: This one may have weird readings if the values get to high, let me know.
Old Feb 2, 2013 | 04:21 PM
tgtrotter's Avatar
tgtrotter
2005 6.0 CANSF
ALL KOEO
ICPv 0.22
BARO 28.8
MAP 14.0
EBP 14.2
THANKS BENNY
Old Feb 2, 2013 | 04:29 PM
BLADE35's Avatar
BLADE35
2005 6.0 CANSF
ALL KOEO
ICPv 0.22
BARO 28.8
MAP 14.0
EBP 14.2
THANKS BENNY
BAR MAP EBP Should be within 1-2 psi of eachother at KOEO
Check this One out is the Code entered Right????
Or could it be in KPA or whatever instead of PSI
Electrical wise the ICP Sensor Looks OK so FAR ICPV to be good should be .18-.24volts at KOEO
Lets Go Ahead and Test each sensor and get 3 Values per each sensor
this how below and you check every sensor basicaly this way
OPERATING VALUES
Just make shure the numbers are taken exactly like this
Truck in PARK OR NEUTRAL all times during test
ECT at 190* or close to And EOT at 185* or higher
A/C OFF
#1-------KOEO=Key On Engine Off =record EACH sensor value and POST IT!!
#2-------Low Idel (truck idel on its own)=record EACH sensor value and POST IT!!
#3-------High Idel (2500RPM)=record EACH sensor value and POST IT!!
ALL^^^^^^^^^^^^^^^^^^^^^^^^^ Taken in Park or Nuetral
Old Feb 2, 2013 | 05:45 PM
tgtrotter's Avatar
tgtrotter
EOT 193
ECT 186
*CEL P2284 CAME ON AROUND 2000 RPM WHILE DRIVING TO WARM UP
KOEO
Baro never moved on any 28.8
I used your sg tx/mth etc values and bar read 0.1 across the board
EBP 14.2
MAP 14.0
ICPv .22
@IDLE 800RPM
Baro 28.8
EBP 16.3
MAP 14.4
ICPv .81
*COULD NOT GET TRUCK TO HOLD STEADY HI IDLE ! Like i posted after 2000rpm it just revs to outer space on its own ! YES I have a steady foot. It's like the throttle position sensor isn't working past 2000 rpm. Can't even catch it on the way down rpm wise.
best readings at a micro glance AS IT SHOT PAST AND BACK AGAIN 2500 rpm
BARO 28.8 or 0.1 again
EBP 17.1
MAP 14.7
ICPv 3.02
Shoot Benny I don't know it's getting worse and i'm driving our suburban neighbors nuts coming and going and trying to hold a steady idle.
Craazzzzy
Old Feb 2, 2013 | 06:01 PM
tgtrotter's Avatar
tgtrotter
Im reading here others with throttle sensor problems was dead accel and it would throw specific codes.
How about turbo vanes sticking ? I'm getting puffs of black smoke out tailpipe when accelerating hard. Just the two codes though, no pending
Old Feb 2, 2013 | 06:12 PM
BLADE35's Avatar
BLADE35
So it sounds like the truck has a Mind of its Own
So Far the Numbers Look OK Except Baro and it might be reporting in Kpa IDK
the SGII if you scroll thrw menu will have an Option make shure its in PSI
Hang on I will check the SGII Code
Old Feb 2, 2013 | 06:24 PM
cheezit's Avatar
cheezit
benny check your sg formula for baro. i suspect its wrong. 28.8 /2= 14.4.
looks like kpa to me
BLADE35's Avatar
BLADE35
I think the BARO Code should report in psi
IDK Cheezit according to this 14psi equals 96.5KPA
BAR 07E0221442 046285140642 3010 001D00500000 Barometric Pressure (kPa(PSI)). Alternate to BMP
Key On = 96.5 (14)
Low Idle = 96.5 (14)
High Idle = 96.5 (14)
Operating Range = 50
120 (7.3 17.4)
Old Feb 2, 2013 | 07:07 PM
cheezit's Avatar
cheezit
Key On = 96.5 (14)
120 (7.3 17.4)
sorry iirc wrong there should have said "hg
Old Feb 2, 2013 | 07:10 PM
tgtrotter's Avatar
tgtrotter
I APPRECIATE your help guys. I'd like to figure this out. If you followed my threads you know yesterday i got my truck from shop who replaced egr/oil coolers, cleaned manifold , egr valve and center section of turbo, oil and coolant. When i picked it up owner said over revving and codes. I said never ever did that but we agreed may be tuner glitch so i took it home and returned to stock and now here i am. Shop closed today
My turbo is 14 months new, my egr valve reads 100evm 104evd 3/4 throttle. I was just outside wiggling the wires to the icp and egr. nothing and they are very clean. My OBDII light is lit. The baro reading has me wondering ?
I need to be informed when i take it back monday. Not pointing blame but it didnt do any of this before it went in.
I'm just tired, real tired of how dealers and shops have a hard time diagnosing a 6.0 but also ALL the variables of what could be and can go wrong.
Sorry i swung into that dealership with my 7.3 thinking i was getting something better. Damn the EPA !
