Extremly Technical Door Glass type Question
Old Jul 18, 2013 | 01:56 PM
oldmerc's Avatar
oldmerc
oldmerc
Question Extremly Technical Door Glass type Question
You know those felt washers that reside between the window regulator pins and the window channel. The ones that the manual advises you not to loose . Well I lost them . What would you guys suggest I use in their place ?
Old Jul 18, 2013 | 02:10 PM
raytasch's Avatar
raytasch
Believe Nothing
I've not made replacements for the washers you mention but I have found that a big heavy sheet of heavy felt can be used to make such washers, pads, etc.
Old Jul 18, 2013 | 02:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
???? I have never even seen those?! There were none on either of my windows. Are they to prevent rattles? Or to hold oil?
Old Jul 18, 2013 | 02:38 PM
oldmerc's Avatar
oldmerc
oldmerc
I think they were intended to act as spring washers and take up slack in the mechanism . They were dry as a bone and if you oiled them I suspect they would just attract dust and cause wear or binding . They were there and are mentioned in my manual (the red one)
Old Jul 18, 2013 | 02:41 PM
oldmerc's Avatar
oldmerc
oldmerc
raytasch I will tell my wife you said I could use some sheet felt from her craft room . Can you advise as to colour please ?
Old Jul 18, 2013 | 03:02 PM
raytasch's Avatar
raytasch
Believe Nothing
I am not going to go there I bought a yard of the stuff on line quite a few years back. Cheap, even with shipping. I can't remember how many different things I've used it for.
Old Jul 18, 2013 | 03:06 PM
tinman52's Avatar
tinman52
Welder User
Never seen them either. My windows seem to work fine without them...
Old Jul 18, 2013 | 03:18 PM
oldmerc's Avatar
oldmerc
oldmerc
I am pretty sure they were as Ross suggested , an anti rattle thing . I am also sure lots got lost or forgotten when windows were replaced .
Old Jul 18, 2013 | 03:22 PM
4tl8ford's Avatar
4tl8ford
When I replaced a window in my 52 the washers were oiled and extremely flimsy - I took some cloth from the dog's blanket and cutout washers, I ended up using two layers to make them thick enough that I felt comfortable with - Before I installed them I soaked them with 3 in 1 machine oil then squeezed the excess out of them - The "Specs" I used were drawn directly from my butt and how I felt at the moment - That was over a year ago and so far nothing has exploded and the window continues to crank up and down with relative ease.
Old Jul 18, 2013 | 03:45 PM
oldmerc's Avatar
oldmerc
oldmerc
I had not thought of using the dogs blanket . Since we are so far north ours are nice and thick .
Old Jul 18, 2013 | 04:37 PM
4tl8ford's Avatar
4tl8ford
She really didn't miss it - Just a few less pieces to eat and poop
Old Jul 18, 2013 | 04:38 PM
tip49's Avatar
tip49
Felt washers intact
mine definitely were there when I did my windows, still have them in place
Old Jul 18, 2013 | 04:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
So looking at the mechanism thru the access panel, they go over the pins and behind the glass channel? I just had mine apart two days ago, and as I recall the pins are about 3/8"? Maybe a nylon washer would suffice? (the High Tech solution!)
Old Jul 18, 2013 | 05:59 PM
oldmerc's Avatar
oldmerc
oldmerc
Hmm I do have a selection of UHMW Plastic sheet stock , that might work real well .
Old Jul 18, 2013 | 06:45 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
If Im not mistaken I used the felts you buy to put over battery terminals. you can get em at any auto store.
