Brake line?
Old Jul 18, 2013 | 12:11 PM
Lynnmcmahan's Avatar
Lynnmcmahan
Brake line?
F250 '06 power stroke
Just noticed a (looks like) brake line about 2' long hanging at rear axel driverside. One end hooked to line on top of axel the other end has a nylon fitting and a clip attached. Cannot find where the loose end goes. My only thought is it must be a vent. There is a square hole above the axel in the bed frame that looks like where it should be.
Any suggestions?
Thanks
Old Jul 18, 2013 | 12:32 PM
HeavyAssault's Avatar
HeavyAssault
Yep that is the axle breather line. Just keep it as high as possible.
Old Jul 18, 2013 | 12:37 PM
Per4mance's Avatar
Per4mance
did you suck out the old brake fluid and bleed the lines good,if not get to it because there is most likely moist in there
Old Jul 18, 2013 | 01:07 PM
HeavyAssault
By his description it's a breather line, not a brake line.
Old Jul 18, 2013 | 06:32 PM
Lynnmcmahan
Thank fellows, it had me wondering
AramisVI
Bronco II
Oct 20, 2014 12:06 PM
pace car
Sep 30, 2012 04:11 PM
GIL4X4
Jul 29, 2008 04:38 AM
Rediranch_too
Oct 8, 2004 02:31 AM
84xplorer
May 6, 2002 01:05 PM
