Sponsored by: Real Truck
Opinions on code scanners
Old Jul 18, 2013 | 07:21 AM
snatchal's Avatar
snatchal
2nd Gear
I just bought a 2008 f350 4wd with a 5.4
Check engine light is on. abs light also comes on sometimes. Since I plan on keeping this truck for awhile I have decided to buy a code scanner.
Any opinions on which one to buy? Do they read the abs codes as well?
Old Jul 19, 2013 | 08:30 PM
Popeye2347's Avatar
Popeye2347
I am very happy with my Scangauge. I bought it online from Autozone but think a better deal could have been found.
It was bought for a 1996 Mustang GT that had a recurring check engine light. Found and corrected the problem, reset the computer and all was well. Used it to check a few other autos, very very easy. Hooked it to me 2006 SD with 6.0 to monitor temps, etc, but then found a SCT 9600 for a good price already loaded with the tunes I needed.
Old Jul 19, 2013 | 09:31 PM
Yahiko's Avatar
Yahiko
It really depends on how deep in you want to go.
The Scanguage will only read so much and it not
the best on reading codes.
The AE with the Ford bundle or if you have the money
a Snap-on.
Sean
Old Jul 19, 2013 | 09:57 PM
RBlac's Avatar
RBlac
Sean
Can you elaborate on this a little.. Never heard of the AE.
Old Jul 20, 2013 | 12:59 AM
Yahiko's Avatar
Yahiko
Here is the link.
AutoEnginuity
I don;t use one because I have a Snap-on Solus
but it will read things that the SGII (Scanguage II) won't and
also things that the "FREE" scans at the auto parts store
won't report to you also.
The SGII is a good programable gauge set but it has limits and
that is the problem with the cheeper scan tools.
Sean
Old Jul 20, 2013 | 01:53 AM
RBlac's Avatar
RBlac
Thanks Yahiko, Will check those out.
Old Jul 20, 2013 | 08:14 AM
2000silverbullet's Avatar
2000silverbullet
I've heard great things about AE.
Or you can go the cheap route, get a BT OBD adapter and the Torque app.
Old Jul 20, 2013 | 10:50 AM
Wolfboro's Avatar
Wolfboro
The very basic models provide only error codes (if that is enough for you ). One step up models will provide "live data" which could be helpful for some diagnostic work . One more step up may provide some "charts" that can be useful for advanced diagnostic work. Another step up can provide ABS brake codes . More advanced models will give you transmission error codes ,etc.
You have to decide how far you want to go and select a model accordingly.
Good luck,
rtalich
Mar 31, 2011 07:52 AM
<TDUB>
Modular V10 (6.8l)
Dec 25, 2008 10:44 AM
cartmanea
Oregon Chapter
Mar 6, 2008 01:40 AM
Claus
Iowa Chapter
Aug 29, 2004 10:18 AM
stackclimber
Feb 17, 2004 07:05 AM
